01-29-2020, 02:27 PM | #1 |
What ball joints for the ECE 2.5 drop spindle for 1968 Chevy C10?
I purchased a complete 5x5 front disc brake conversion kit from ECE and it included the 2.5 drop spindles for my 1968 Chevy C10.
I forgot which ball joints the spindle will need? I tried calling ECE but have not received a call back as I also wanted to purchase some parts while they are having a sale. |
01-29-2020, 02:48 PM | #2 | |
Re: What ball joints for the ECE 2.5 drop spindle for 1968 Chevy C10?
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
01-29-2020, 04:10 PM | #3 |
01-29-2020, 04:41 PM | #4 |
I highly recommend Moog (problem solver) for your ball joints or any suspension replacement parts.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
01-31-2020, 06:53 PM | #5 |
Yes u can go to your local parts store and get what u need. Moog problem solver is 1 of the better ones made. The upper bolts n so u should get new hardware with the ball joint. U can also order online thru rock auto. Get some grease for ur gun while u are there. Dont make 2 trips if u dont have 2.Let us know how it turns out.
01-29-2020, 03:27 PM | #6 |
As an fyi, ECE has closed it's doors recently. Sad news for sure as they were a go-to resource for parts and tech info for just about all of us here on this board. But this is most likely why it will be difficult to get a response from them if at all.
02-01-2020, 11:16 PM | #7 | |
I used Moog suspension & steering linkage.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-02-2020, 10:01 AM | #8 |
I replaced all of my front suspension with Moog from Rockauto on my 67 and wrote all the part #'s down in my build book if anyone wants them .
I made a "build book" to keep track of all the upgraded parts and pieces ,it has the part #'s ,Where I bought them , and when so I have an easy reference if anything needs to be replaced down the road . or for use by the next owner .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-09-2020, 06:27 PM | #9 |
GOM, I am curios which upper ball joints you used. I am trying to install some Hotchkis upper a-arms with proforged 101-10037 and they simply don't fit. The MOOG equivalent is the K6024. My truck is a 69 that I converted to ECE discs many years ago. Thought I saved the receipt but of course I can find everything but the spindle info...
