Old 01-29-2020, 02:56 PM   #1
rgunlock
rgunlock's Avatar
Whose rear mounted tank for C20/C25
Hi, I've gone through dozens of threads on rear mounted fuel tanks and filler options. While I've gotten a lot of good ideas, the threads I've seen are hard to sort out details.
I've got a 71 GMC C25 that I'd like to convert to side fill versus coming up in the bed 4 feet back (including open tailgate) that it has now. Who makes a side fill tank with mounting flanges for C20/C25 that doesn't have problems with interference with frame crossmembers, bed cross sills, etc.? --Thanks
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-29-2020, 08:44 PM   #2
rgunlock
rgunlock's Avatar
Re: Whose rear mounted tank for C20/C25
I ask because its my impression that the rear frame rails are different between C10 and C20 and might affect the position of the tank mounting flanges. Vendors like LMC don't seem to make a distinction between C10 and C20 for these and I'd like to get a tank specifically for my C25. I've tried contacting Boyd's Welding for a tank because it looks like a good one, but its listed for C10 and I haven't been able to get a response to my PMs or email through their website.
So what have you used, or what can you recommend?
Thanks, Rick
Rick
Old 01-29-2020, 08:52 PM   #3
Wobpb377
To my understanding the only major differences are the suspension parts. Heavier duty for the c20 (3/4 ton)
Wobpb377 is offline   Reply With Quote
Old 01-30-2020, 11:08 AM   #4
rgunlock
rgunlock's Avatar
Thanks. If that's the case no problem. I was under the impression that the frame rails were taller for 3/4 and 1 ton versus 1/2 ton. If that's the case, the tank mounting flanges would need to be lower to keep the fill and vent pipes above the frame rail.
Rick
Old 01-30-2020, 11:25 AM   #5
Wobpb377
Hope someone else chimes in as I don’t hVe a lot of experience. Juts what I read and who’s to say all is true on here.
Old 01-30-2020, 11:39 AM   #6
rgunlock
rgunlock's Avatar
Yeah, I've been doing searches more focused on frame differences than what tank to use. Most of what I'm finding indicates that the 3/4 ton frame is thicker material than the 1/2 ton frame, but the frame rail height is the same.
If that's true, I'd think a tank advertised for C10s would work for me.
Rick
Old 01-30-2020, 11:59 AM   #7
Slowboat
Is there also and additional rear brace for the c20?
Slowboat is offline   Reply With Quote
Old 01-30-2020, 12:28 PM   #8
toolboxchev
To my understanding, through this site, the frame rails are the same, they were made of a high strength metal.
toolboxchev is offline   Reply With Quote
Old 01-30-2020, 06:12 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Whose rear mounted tank for C20/C25
I don't know about the frame differences but I just did a rear frame tank install on my 68. I used a "no limit' 19 gallon tank with side fill. You have to cut the frame out but the tank comes with a stiffener piece to weld back in. It also gives you the flat plate strips to use but I decided to slide it into the frame and didn't use them. This gives a little more ground clearance.
I had them do the electric fuel pump mod also so if later on I decide to go with fuel enjection.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-30-2020, 06:22 PM   #10
68Gold/white
rgun,
Be patient, someone here knows, exactly!!! I do not...
68Gold/white is offline   Reply With Quote
Old 01-30-2020, 07:03 PM   #11
rgunlock
rgunlock's Avatar
Thanks guys!
I know that I should have about 3" between the bed floor and the top of the frame rail to run the filler and vent hose as long as the tank lines them up between the bed cross sills. It looked like (from pictures) the Boyd tank fill pipe was intended to point through that space as long as the top of the tank is at the correct level. So perhaps notching the frame like Andy shows might not be necessary although that looks like a nice tank. On my LWB, the tank would be located more forward in the frame with another crossmember behind it. I'd have to get more measurements to see if that "no limit" tank's filler location would work. From memory I'm thinking it would come out very close to the wheel well.
I did find a post from SS Tim on this site that indicates only a 0.07" difference in height, but I'm thinking that refers to the portion of frame below the cab. In the rear where the tank would mount I know it isn't nearly 6" tall.
C10 127"- 6.04" section height, 2.53" flange width, 0.156" thick, 2.98 section modulus
C20 127"- 6.11" section height, 2.46" flange width, 0.194" thick, 3.71 section modulus
I'll keep hunting for info and watching this thread. Thanks again for those chiming in.
Rick
Old 01-30-2020, 07:10 PM   #12
Andy4639
Old member
Andy4639's Avatar
Rob @ No Limit is a member here and he may would build you a tank wherever you want the fill tube. I know on this tank you have 2 options, either top fill are side. I would think he would be happy to put it wherever you needed it.
Would be worth a call.
(865) 940-1503
Old 01-30-2020, 07:20 PM   #13
rgunlock
rgunlock's Avatar
Thanks! I'm familiar with Rob from years spent on this site, but had no idea he did custom tanks.
Rick
Old 01-30-2020, 07:36 PM   #14
rgunlock
rgunlock's Avatar
Originally Posted by 68Gold/white View Post
rgun,
No problem with being patient on this one. This truck's bed has 4 holes used at some point for fillers, including 2 large ones that used to be for auxiliary tanks. Plus the original in the cab. I want to patch at least the 4 holes in the bed before cutting a new one!
Rick
