01-29-2020, 09:05 PM | #1 |
Lowered too much! Need options
Hey everyone!
I'm pretty sure I dropped my truck too much. and need some options to raise it to clear the tires. Bummed about it after the lowering kit and new disc brake conversion. I installed 2.5" drop spindles and 2" lowering coil springs from Brothers. I'm running P245 50 20 tires on 20" rims. As for the rear, I have on order from Western Chassis lowering leaf springs - 4" drop Check out the photo and let me know what you might recommend. Thanks! Fred |
01-29-2020, 09:23 PM | #2 |
Re: Lowered too much! Need options
If the rear is still at stock height, just wait....when you lower the rear, the front won’t look so extreme. If at that point, it’s still too low, put the stock front springs back in...
01-29-2020, 09:38 PM | #3 |
OK, they should be here in a week. I'll install them and wait and see if the tires rub. Thanks for your time
01-29-2020, 09:49 PM | #4 |
What's the wheel size and offset? My truck is lowered 4 1/2" front 7" back with 235 55 17 and 275 55 17 with no tire rub. 8" and 9" rims respectively, both zero offset (4.5" bs front 5" bs rear)
01-29-2020, 10:02 PM | #5 |
I have no idea what the off set of the wheels are. I know the wheels are 20"
01-29-2020, 10:42 PM | #6 |
Nice looking truck, you got more pics? Actually, I think it sits just right...
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
01-29-2020, 10:47 PM | #7 |
If you want it to sit level, and are going to use 4" drop springs in the rear, the 2.5" drop spindles are all you need in the front. That's what's on the truck in my avatar. If you want it raked, I would leave the front as is.
01-29-2020, 11:02 PM | #8 | |
Old member
01-30-2020, 01:36 AM | #9 |
What is rubbing? Might be you just need to trim the fender where it folds in, if that makes sense. I had an old ford I had to do that with. Just trimmed the fender, and bam, all good.
01-30-2020, 03:14 AM | #10 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
When I first dropped my first truck (72 C/10 LWB) with 2-1/2" drop spindles and 2" drop springs it rubbed in turns and bumps with BFG 275/60R-16's...It was spongey in the bumps, bouncy...So I pulled the 2" drop springs and cut 1/2 coil off the bottom of the factory springs and "wahlah!" I gained 1" clearance and a stiffer rub free ride. I ran my sway bar through the front frame brackets too. If you don't have a front sway bar get one!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-31-2020, 01:09 PM | #11 |
Hey 1badtransam......could you do me a huge favor and get dimension from fender edge to wheel center? I'm trying to nail down springs and spindles for my truck......much appreciated!
Jim
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
01-31-2020, 01:43 PM | #12 |
I did the same thing, 2.5 spindle, 2" spring. It was too low, my wheels were rubbing too.
Swap to a 1.5" spring or use a coil spacer. My truck ended up somewhere around a 4/6 drop. See my post #112 here: http://67-72chevytrucks.com/vboard/s...=609973&page=5
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-31-2020 at 01:55 PM. |
01-31-2020, 05:51 PM | #13 |
I did a 2.5" drop spindle and 2" cpp springs with 245/40/20 and I was rubbing a ton. Switched to stock springs with the 2.5" spindles.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
02-01-2020, 11:17 AM | #14 |
I am by no means the expert here, but as for your options, I think as others have noted, going back to a less spring drop seems the easiest correction.
Although unlikely, consider a change in the rim/tire setup (50 series 20" may be too much for the drop you're shooting for)
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
02-01-2020, 11:54 AM | #15 |
I did the same frontend swap and I think it's to low also. I'm going to put my stock front springs back in and see what it looks like.
02-01-2020, 01:18 PM | #16 | |
From what I understand, a 2.5" spindle drop + 2" drop springs is a 6.5" drop Word is you double the amount of the coil spring reduction, so a 1" coil spring is actually a 2" drop.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-01-2020, 11:36 PM | #17 | |
If you order a set of "1 inch drop" or "2 inch drop" springs, those springs are designed to be that much lower than a stock set up. The only caveat to that is these trucks are 50+ years old and the stock springs may be sagging by a whole 1/2"-1" already, so you might not get as much drop as you thought because you're comparing it to a worn out suspension.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-02-2020, 09:45 AM | #18 |
good info here was looking into 2.5 drop spindles and a 2" spring maybe i will just got with the spindle for now, would a modular drop spindle from cpp bring the wheel in a little just looking through the products available and find most drop spindles push your wheels out modular ones are supposed to retain track width, im sure someone knows more about this and it would be costly to swap out drop spindles now.
02-02-2020, 07:18 PM | #19 |
Another question for 1badtransam:
Great fender emblems, where'd you find those!? Jim |
02-04-2020, 01:03 AM | #20 | |
02-10-2020, 05:40 PM | #21 |
Thanks everyone for all of the input! Rear leaf springs fin ally came in. I just put them on and dropped the truck. I love how it sits. I ended up putting a new booster/MC/PV in it so now have to bleed the brakes to see if and how much it will rub up front. I like the spacer idea.
I'll get those measurements for you SactoJim. The side emblems are a custom job by me. I had the original ones rechromed, repainted the GMC red and added my own 3M graphic of the American Flag. I'm glad you noticed it - first person. Here is a new photo of how it sits now and the one below is what it looked like when I bought it. Yes.. it's a long bed. Last edited by 1badtransam; 02-10-2020 at 09:23 PM. |
02-10-2020, 05:52 PM | #22 | |
02-10-2020, 05:53 PM | #23 |
02-10-2020, 05:54 PM | #24 | |
Very nice truck! I like the idea about adding the spacers. |
02-10-2020, 05:57 PM | #25 |
