![]() Join Date: Sep 2009
Tail light/brake light plug re-locate
I believe this plug is for the tail light and brake lights as the wiring is running to the back of the truck. I installed a lokar gas pedal upgrade and the wiring plug is going to have to be re-located.
Is there a common spot for the re-location? Also, is a stepper-drill the best tool to drill the new hole? Thanks for any help. |
![]() Join Date: Aug 2019
Re: Tail light/brake light plug re-locate
I filled that hole and ran mine into the cab in the floor behind the seat. Then spliced in new wire from the under dash plug down the drivers side along side the other wires and covered them over with the carpet.
Old member
Why is it in the way? The cable pulls it tight to the wall but in operation the pedal pulls the upper part a way from the wall. You should have plenty of room for the plug.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Did that firewall fitting come with the new lokar pedal ? if not were did you get the fitting ?
the female plug isn't actually in the way but the wires and male end are
#6 | |
They should sell the pedal (XBAG-6164) and cable kits (XTC-1000HT) together but they are separate kits. You need both as well as the linkage assembly (XSRK-4000) that mounts on the carb. I will say that the directions that come with each Lokar kit are as good as you will see anywhere this engine & trans swap just keeps growing and growing |
Simply moved the Tail light/brake light plug up and to the left after making that hole a bit bigger.
Then moved the wiring going thru that hole to pass thru the firewall in the same hole as the oil pressure line. Plug on order to fill the hole behind the gas pedal. One day I'll do a body build and clean up the firewall and engine bay. |
