Old 01-31-2020, 03:51 PM   #1
cebra
PS Rag Joint Size
I have a 71 with factory power steering and the original steering gear. Which rag joint do I need? I don't have a very good option to disassemble and count splines as I will need to fix overnight. I searched a ton but find a lot of conflicting threads. Thanks.
LARES 201 For 13/16" 31 spline input shafts with flat and 3-1/4" OD coupler. Info
For 13/16" 31 spline input shafts with flat and 3-1/4" OD steering coupling assembly.
LARES 200
3.25" OD Info
For 3/4" 25 spline input shafts with flat and 3-1/4" OD steering coupling assembly.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
