Old 01-31-2020, 08:50 PM   #1
nsb29
nsb29's Avatar
ECM/speedometer
I have a 2009 6.0 and a 6L80E out of the Pontiac G8 I am told it’s the same as 2010 Camaro and pin 57 is not used does anyone know where I get the signal for the speedometer from
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 02-02-2020, 12:30 PM   #2
kipps
Re: ECM/speedometer
Just guessing a little here, but I'd say plan on using that pin 57 for the speedo. You may need to turn something on in the tune to get an output on that pin at all, though.
That pin 57 is what I expect to use myself.
From what I've gleaned, some vehicles had a wheel speed sensor at each corner. Others did not include rear wheel sensors, and instead relied on a transmission output speed, coming from that pin 57. I can't guarantee this is accurate, but it makes some sense to me.
We're sorta' misusing that pin 57 by expecting it to drive a speedometer. But reports say it works fine.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-02-2020, 04:08 PM   #3
nsb29
nsb29's Avatar
Re: ECM/speedometer
Thanks that’s what I have read, I have a print out from lt1 swap on 2010 Camaro witch I used to build my harness and have been told was the same as the 09 G8, and it shows it’s not available. I called current performance but was told he didn’t think it could be turned on if it said not available, but I had had to Email the tuner and now I’m waiting for a reply. Was hoping sum one had been down this road
Old 02-02-2020, 11:17 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: ECM/speedometer
Worst to worst 100 one speedo module from dakota
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
