Old 02-01-2020, 02:26 AM   #1
Ptjsk
Cup Holder
Had to make something for a cup holder, as there just isn't too much available out there.
This is in my Jimmy, but would work for a column shift truck too.
Test fitting prior to carpet install.
Pat
Ptjsk is offline   Reply With Quote
Old 02-01-2020, 02:46 AM   #2
Tuff Gong
Tuff Gong's Avatar
Re: Cup Holder
Pretty cool idea, I don’t think I have seen that before. How is it when you reach for the drink? Are you going to bolt it in place?
Tuff Gong is offline   Reply With Quote
Old 02-01-2020, 09:31 AM   #3
Ptjsk
Re: Cup Holder
I built a similar one for an old '75 Ford truck I had. I let it go when I sold the truck.
It's not too bad at all when reaching for a drink. Obviously not as nice as it would be if in a console, but definitely doable.
After dynamat and carpeting, I intend to secure (bolt) it into place. I would hate to have an accident and have that piece of iron become a projectile inside the cab.
Pat
Old 02-01-2020, 11:06 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cup Holder
Nice. I used a old S 10 shifter and cup holder in my 71 C 10. I cut the front/back on the console off so it would fit.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-01-2020, 06:06 PM   #5
LS short box
Re: Cup Holder
I did something similar using two pieces of exhaust tubing welded to a flat plate with a small extension with a hole drilled in it so I could slip it under the trim ring of the shifter and hole it in place with one of the trim screws.
LS short box is offline   Reply With Quote
Old 02-02-2020, 04:30 PM   #6
chevnkevin
chevnkevin's Avatar
Re: Cup Holder
well it has cup holders and more
works great and fits great
chevnkevin is offline   Reply With Quote
Old 02-03-2020, 09:04 AM   #7
Jason Banks
Jason Banks's Avatar
Re: Cup Holder
That's a Lincoln Navigator or Ford Expedition console.
Jason Banks is offline   Reply With Quote
Old 02-03-2020, 04:43 PM   #8
68 P.O.S.
Re: Cup Holder
Beautiful, wanna trade for my pos?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
