02-02-2020, 12:08 PM | #1 |
292 3 OTT Clutch Advice
I'm finally going to put my 3 speed with a BW overdrive into my 72 C20 with a 292. I haven't bought a clutch for something like this in 40 years. Who makes a good clutch/pressure plate these days? Thanks.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
02-02-2020, 02:34 PM | #2 |
Re: 292 3 OTT Clutch Advice
I have had real good luck with Luk clutches, well built and reasonably priced.
02-03-2020, 03:39 PM | #3 |
I would look for a local clutch shop. There are places that build clutches for big trucks that will rebuild smaller ones as well. I bought a clutch kit from a chain store for $150 ish. It was all wrong. Got turned onto a local place here in Chattanooga called Feltons Clutch. They had what I needed in stock for about $100 and turned my flywheel too. Maybe you have something local as well?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-04-2020, 09:34 AM | #4 |
Thanks Randy and Mark.
02-04-2020, 01:11 PM | #5 |
I swapped a 292 into a 68 that originally had a 250. The clutch I used didn’t last long, nor the cheap ass motor mounts available today..good luck. Tons of torque in those old 292’s
71 C-20 07 Magnum RT AWD |
02-04-2020, 07:59 PM | #6 |
I have a Centerforce II. 11'', between my 292 L6 and an SM465.
02-04-2020, 09:37 PM | #7 |
Thanks!
02-04-2020, 09:39 PM | #8 |
I was hoping you would reply. So an 11" is normal. I should have it out tomorrow. Thanks!
02-04-2020, 11:36 PM | #9 | |
But an 11'' is good enough unless you're getting a 454. Eleven inches was standard for the 292 and SBCs up thru MY 1971.
02-05-2020, 01:27 AM | #10 |
Back in the day when I was working as a mechanic and these trucks were still daily driven every clutch job I did on one I upgraded to a 12 inch regardless of the engine and drivetrain. Most fly wheels are already drilled for the larger clutches and it’s a built-in operation and just a few bucks more.
Steve weim55 Colorado |
02-05-2020, 04:43 PM | #11 |
Thanks Steve
02-05-2020, 05:03 PM | #12 |
If you're already running a 12'' don't downsize.
02-05-2020, 05:43 PM | #13 |
Pulled the engine today, I'm gonna open up the bellhousing tomorrow to see what I have. I bet it's an 11.
02-06-2020, 12:34 AM | #14 |
Who Changed This?
Could be. I had '64 Impala with a SHP (300 HP 327) with a close ratio 4-speed and a 3.91 posi with a 10" clutch. It would smoke the clutch before it would smoke the tires. I would have liked that 11" clutch.
