Old 02-03-2020, 10:12 AM   #1
CJ2A
CJ2A's Avatar
Fifth Wheel
I need to install a fifth wheel ball inmy 1971 K20 to pull our stock trailer and horse trailer. I have not found a manufacturer that makes a fifth wheel hitch for the 67-72 pickups. Should like a hide away ball. What have others done ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 02-03-2020, 11:12 AM   #2
tdangle
tdangle's Avatar
Re: Fifth Wheel
You may need to adapt a hitch for a newer truck and do some fabrication. A lot of trucks have a 34" wide frame, so it shouldn't be too bad.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-03-2020, 11:18 AM   #3
Sheepdip
Sheepdip's Avatar
Re: Fifth Wheel
I bought this one and made my own parts to attach/mount to my frame.
https://www.etrailer.com/Accessories...All%20Products
Sheepdip is offline   Reply With Quote
Old 02-03-2020, 06:57 PM   #4
burnin oil
Re: Fifth Wheel
You wond find a kit. Most cheap universal's are weld in. Looknfor the highest wieght capacity and you will not buckle it. By the way you want a gooseneck ball and plate. A fifth wheel is the thing on the back of a semi. I don't mean for that to sound mean but I can see how it could be taken that way in print.
burnin oil is offline   Reply With Quote
Old 02-04-2020, 12:10 AM   #5
CJ2A
CJ2A's Avatar
Re: Fifth Wheel
Thanks Everyone
I like the pricing on the Curt
I tried to specify what I was looking for in the description by saying “fifth wheel ball”
B&W responded that the under bed hide-away-hitch for a 1973 Chevy 3/4 ton 4x4 will fit a 1971 Chevy 3/4 ton 4x4 pickup. I do not have a square body and was wondering the frame inside dimensions & out side dimensions ? Are the measurements similar to a 1971 ?
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
Old 02-04-2020, 07:43 AM   #6
Keith Seymore
Keith Seymore's Avatar
Re: Fifth Wheel
That sounds more like a "gooseneck" to me.
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-04-2020, 08:25 AM   #7
Mike C
Mike C's Avatar
Re: Fifth Wheel
I bought a ‘83 crew cab recently that had a smooth 2.2” sleeve in the bed and tried to figure out what sort of ball shank THAT was! I found that it is a setup to make your own gooseneck hitch. The sleeve and the ball can be bought from 4 Wheel parts. Then with an 8” wide c-channel and a 4” wide c-channel you can make your own.
On my truck the 8” is welded to the frame, but I would put flanges on it and bolt it in. The 8” piece fits flat to the bottom of the bed over the top of the frame rails. Flanges would be welded to the ends of the channel and bolted to the outside of the frame. The 4” channel is about 15” long and welded to the bottom the 8” channel the opposite direction forming a box. Then the sleeve is welded between the two pieces of channel. Now the smooth ball drops in and is kept from pulling out with a hitch pin. Add your self some spring loaded tie down loops like the B&W turnover ball setup has.
Not as slick as the turnover ball in action since you have to crawl under the truck to pin/un-pin, but you should be able to build it for not much more than a $100 and still have a removeable ball. I’ll get link to pieces and edit post.
Cheapest place I found. Get the 3” sleeve since it minimizes up/down movement with the pin. I think they have free shipping if you spend $75.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.4wheelparts.com/p/bw-hit...R-BQVL-HB94013
https://www.4wheelparts.com/p/bw-hit...iABEgKUq_D_BwE
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-04-2020, 09:43 AM   #8
Jcfcamaro
Jcfcamaro's Avatar
Re: Fifth Wheel
I can measure my k10 frame if there the same as a k20. J
Jcfcamaro is offline   Reply With Quote
Old 02-04-2020, 10:01 AM   #9
CJ2A
CJ2A's Avatar
Re: Fifth Wheel
Yes, “Gooseneck” thanks burnin oil & keith Seymore
I like the 8” & 4” C-channel, it sounds a lot stronger than the angel iron cross braces that come in the kits, thanks Mike C
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
