Any trick to installing coil springs in 1968 Chevy C10
Are there any particular things to watch out for when installing front coil springs into a 1967-1972 Chevy C10?
I am installing some front 2.5 lowering springs and want to make sure I get them installed correctly. |
Still Green but learning
Re: Any trick to installing coil springs in 1968 Chevy C10
Just did this in the fall. I did mine without pulling any of the control arm bushings or anything. There are 2 u bolts on each side holding the base of the spring up. I put a short chain around the spring and locked it together to the base so it didn't get away from me. Unbolted the 4 u bolts and let the base down easy with a jack.
Did the reverse for the install. While the springs were off I should have done the tie rod bushings, but I was able to do them later... just more difficult. Now getting new tires and will have alignment done shortly after to make sure its all good.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
I should have mentioned that I am in the process of rebuilding the entire front suspension and I have already rebuilt then installed the upper and lower control arms complete with ball joints BUT i have not installed the spindle yet.
Is there a certain particular way the front coil springs are fitted into the lower control arm and fit into the upper portion of the cross member? |
![]() Join Date: Feb 2009
We installed factory height coil springs on 2.5" drop spindles last year, so a little tougher to install than original right.
The big block was on the frame, and the weight of my two sons (400 lbs) on the block. The frame was supported by many stands, and blocks underneath the engine cross-member. Floor jack underneath the lower A arm, I'm pumping away, my son says look. The rear of the frame was well off the jack same side ![]() Good idea to secure the coils with a chain or ratchet tie down. Other than that what 68Stepbed said, great video.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-04-2020 at 01:31 AM. |
![]() Join Date: Feb 2002
Apology for hijacking, but expert front coil advice is needed:
On my '68 C/10 Stepside, I've noticed the passenger side dips about 2-3'' lower than the drivers side. I had the OEM front coils replaced in the mid-'80s with Moog HD coils. Stock stance. Looking at coils on RockAuto, I see Variable Rate, Constant Rate and Heavy Duty springs listed. What's the difference?
From what I've heard. No first hand experience.
Variable rate is usually like 3 springs welded together. Can be good for a softer ride unloaded, and higher spring rate when you are loaded. Can be weird when you hit the transition points though. Constant rate will always compress at the same rate. More predictable, but gives a harsher ride unloaded. Heavy duty will have a higher spring rate than standard. The half ton heavy duty springs are basically 3/4 ton standard springs. The AC Delco springs listed on Rock Auto for a 68 C10: Front Standard - 2406 lb load rate, constant https://www.rockauto.com/en/moreinfo...29743&jsn=2216 Front Heavy Duty - 2600 lb load rate, constant https://www.rockauto.com/en/moreinfo...29743&jsn=2217 Rear Variable - 950 lb, variable https://www.rockauto.com/en/moreinfo...29743&jsn=2218 Rear Heavy Duty - 1700 lb, variable https://www.rockauto.com/en/moreinfo...=2219&jsn=2219 EDIT: In figuring out why one side is lower. Park on level ground with the E brake off. Measure from the ground to the top of the wheel well on both sides, compare. Measure from the ground to the bottom of the lower control arm on each side to be sure that is the same. Look around for anything worn or different between the sides. See if you can measure to determine how compressed the spring is. Shocks can play a role also if they are worn.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#8 | |
![]() Join Date: Jan 2016
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
rpmerf-- Thanks, Man. I'll bet it's a bad shock.
