02-03-2020, 11:44 PM | #1 |
Frame mount hitch
I purchased a Drawtite hitch 41504, a class 3 hitch with max rating of 1000 lb / 10,000 lb gross weight. Bought at Amazon for $120.
Happy to report install was easy and I was able to keep the spare tire. I bolted the side pieces to the cross piece of the hitch and then raised it into place after dropping the spare tire. I used C clamps to hold in place while I marked the holes. Drilled 6 1/2" holes stepping up from 1/8" to 1/4" then 1/2". (Hint: Use new or sharpened drill bits) Bolted into place and raised tire into place. I was not able to secure the tire with the cross piece as the bar was hitting the side plate of the hitch on the passenger side. I placed 2 short pieces of 2x6 on top of the tire to take up the gap between the top of the tire and the 2 bars the top of the tire pushes against and was able to secure the tire.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-04-2020, 12:43 AM | #2 |
Re: Frame mount hitch
Looks good!
02-04-2020, 09:40 AM | #3 |
Try spinnin 4 rear tars
Glad to see that it fits with the step bumper. How far back does the receiver tube stick out, any, a lot?
Too bad it doesn't tuck up closer though. For $120, I could live with it (or modify). Thank you for the info!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
02-04-2020, 11:13 AM | #4 |
It is about 3 inches back under my bumper
02-04-2020, 03:08 PM | #5 |
Looks great Terry. Would you mind posting a picture from the lower side view so I can see where the end of the hitch resides?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
02-04-2020, 04:02 PM | #6 |
Here you go. As you can see from the underside of the bumper, the drop hitch was welded well. It took a cutting torch and bit of work to remove it. I haven't bothered to clean it up. Let me know if this is what you need.
02-04-2020, 06:19 PM | #7 |
Nice, Would that work the same for a '68 LB C20?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
02-04-2020, 08:53 PM | #8 |
I would think so. Can't image they changed the frame much if at all.
02-04-2020, 10:01 PM | #9 |
Proprietor of Dale's Corner
Thanks for the info. My "Buddy" was going to charge $300.00 for the same part #. I ordered it through Amazon.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-05-2020, 01:00 AM | #10 |
Good info.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
02-05-2020, 02:57 PM | #11 | |
Brian
02-13-2020, 10:46 AM | #12 |
I installed mine yesterday. Fairly straight forward installation and fits nice.
