Old 02-04-2020, 11:17 AM   #1
truckin 79
Blower fan motor no A/C
I just replaced my blower fan motor in the 79, it started squealing like a pig in the cold. The thread about missing blower motor resistor got me thinking. Is this blower motor a 3 speed or 2 speed motor? I sprayed out plug to resistor because it was pretty dirty. Well when I cleaned it the fan motor only comes on 2 speed low and high. In low speed the new motor wines a little. When I turn radio on does not really bother me. I was just wondering if I go back to parts store and try and see if I can get a quieter one or if all fan motors in low sound this way.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 02-04-2020, 01:16 PM   #2
Bandit130
Bandit130's Avatar
Re: Blower fan motor no A/C
I have replaced a few due to squealing so I would return for exchange. Be sure you have a good motor ground. Sometimes the ground wire that normally connects to fan housing may not be good there. Move to a proper location to insure good ground. Next I would check the resistor, it may be bad. Check fuses too. I'm not sure about motor speed being 2 or 3. The resistor determines that. Mine is a 4 speed w/ac.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 02-04-2020, 02:03 PM   #3
Dead Parrot
All the GM blower motors I know of from the square era don't have speeds. They are a simple one power wire setup. The different speeds are made by the resistor setup(and maybe a relay) + fan switch that supplies different voltages to the motor.
The motor itself should be mostly quiet at all speeds. You will get a fair amount of moving air noise.
That last time I had to replace a blower, it took a couple tries to get a quiet one. QC seems a lost art on vehicle parts.
Dead Parrot is offline   Reply With Quote
Old 02-05-2020, 05:25 PM   #4
hatzie
Moderator
hatzie's Avatar
AC and non AC blowers are wired differently.
The blower on the AC systems has three positions through the resistor and HI is routed through the blower relay on the AC box.
The non AC systems have two positions through the resistor and HI is direct to the motor.
Are you getting RF motor noise on the radio or the fan itself is squealing mechanically?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-06-2020, 11:50 AM   #5
truckin 79
No RF interference luckily just like a whirling noise in low position. If for some reason the radio stopped working and I had to just listen to fan motor on low speed it might get annoying. I might try and get another fan motor when it warms up in the spring time and replace since it is a lifetime warranty part. It is a little too cold in CO right now to mess with it, I am just glad it keeps truck warm and does not squeal on start up. I am sure the neighbors appreciate that.
So just to be clear on non-ac cars the switch is off-low-high, is that correct
