02-04-2020, 11:52 AM | #1 |
Quick A/C Wiring Question
The wiring diagram doesn't really show me the answer. This is the plug that goes on the back side of the A/C control switch on an AAW factory fit harness. What is the short brown wire for?
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
02-04-2020, 12:19 PM | #2 |
Re: Quick A/C Wiring Question
That should be the power feed from the fuse panel Edit: I believe its labeled ac/heat on the fuse panel terminal and protected by a 25amp fuse
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com Last edited by Curtb1971; 02-04-2020 at 12:22 PM. Reason: See |
02-04-2020, 01:18 PM | #3 |
Is there an in-line fuse? My harness did not come with one.
02-04-2020, 08:02 PM | #4 |
Old member
Per your picture there should be a inline fuse on it. That's what the small black housing on the end is part of a inline fuse holder.
02-05-2020, 12:24 AM | #5 |
Sure looks like one side of an inline fuse on the AAW harness in your pic. On an oem harness the brown wire goes directly into the fan switch plug but i have seen some eith a small pigtail and packard 56 male and female conectors. The trucks fuse center protects the circuit with a 25 amp fuse so an inline isn't necessary. If you have the oe harness with the wire terminal on the end of the brown wire you can de pin the small aaw pigtail out of the connector and land the oe one in place. Hope that helps
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
02-05-2020, 02:25 AM | #6 |
Couple good answers there....i will try to clarify this.
The factory dash harness has a brown wire which powers the switch for ac or heat only switches, that wire plugs into the position of that short wire, remove the stubby wire and insert the brown dash harness wire. As others said, the brown wire originates at the heat/ ac fuse, i think heat gets 15a fuse and Ac gets the 25 a fuse, the fuse box is marked as such. |
02-05-2020, 09:02 AM | #7 |
Thanks for the responses guys. I was confused why the A/C harness from AAW had the end for an in-line fuse but it didn’t come with the other end. I was thinking it was unnecessary because it is protected at the fuse box. I thought maybe I was missing something.
