Old 02-04-2020, 04:57 PM   #1
kljfamily
swag to universal joint swap on steering
Hello all,
On my 66 Suburban the PO installed P/S but must have mis-drilled the holes. The power steering does not line up perfectly so the swag (steering coupler) though attached it does not bite well in the splines causing it to come loose (luckily I was going slow when it happened).
To fix this alignment issue I heard you can switch to a universal joint(s).
Does anyone have a write up on this or done it in their c10?
thanks
kljfamily is offline   Reply With Quote
Old 02-04-2020, 06:21 PM   #2
LVPhotos
LVPhotos's Avatar
Re: swag to universal joint swap on steering
You can use a DD if you're willing to grind down shaft. Losing the rag joint will bring vibrations to steering wheel.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-04-2020, 06:26 PM   #3
LVPhotos
LVPhotos's Avatar
Here's the first set up before new colum
Old 02-05-2020, 08:42 AM   #4
kljfamily
Ok, so if I’m thinking of this right I notch after the steering place a coupler there then use a DD shaft and place another coupler at the power steering.
I’d have to find a splined coupler then to attach to the PS.
I have heard it will add vibration but I’d rather have that then the free flying steering wheel I just experienced.
Old 02-05-2020, 10:46 AM   #5
cwcarpenter98
cwcarpenter98's Avatar
Did you grind that yourself or did you take it to a machine shop?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-05-2020, 01:34 PM   #6
LVPhotos
LVPhotos's Avatar
Cut, and ground at home, in place, then splurged on new colum. It would work but 3 on tree colum was just wore out and internals not working, blinkers on steel wire. Divot for set screws
Old 02-05-2020, 01:57 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by kljfamily View Post
Hello all,
thanks
Maybe he could have installed the incorrect spline on the box side? Some PS boxes have 3/4"-30 spline output, most not. Some have 3/4"-36. Before you grind it down I'd check, maybe the fix is the correct steering joint.
If you ever have to turn it in for a core . . .
Old 02-05-2020, 07:44 PM   #8
cwcarpenter98
Sick I'll probably be doing the cut and grind to add a collapsible shaft to mine
Christian Carpenter
Old 02-06-2020, 09:05 AM   #9
kljfamily
I’ll check the splines again and make sure I have the right swag installed.
I’ll also look into the setup for the universal joint and if I go forward I’ll post up pics and how-to.
It’s my understanding that there is a universal joint you can get that will attach directly to the spline without having to shave down the power steering spline.
Old 02-06-2020, 09:08 AM   #10
kljfamily
Here is an example of the u Joint. https://www.cjponyparts.com/borgeson...oducts%20Broad
Old 02-06-2020, 09:21 AM   #11
kljfamily
This looks like a complete kit for 179
Old 02-06-2020, 09:25 AM   #12
The Rocknrod
Moderator
They also make a vibration reducer combo u-joint.
Old 02-10-2020, 10:54 PM   #13
slepysal
slepysal's Avatar
here are some not to good pics of my set up. Using a pick and pull 1972 Van tilt,
a 3/4 36 spline dd u joint and a collapsible lower shaft.
straight shot from column to gear
the blue tape was used for reference and no the splines do not hid bad picture
angle
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-12-2020, 10:46 AM   #14
AcampoDave
AcampoDave's Avatar
The column rods from a 67-72 will fit the 60-66 housing. I swapped mine out in that fashion and then added new bearings top and bottom. I then used Borgeson U joints at the column and the steering box as well as double D tube which was a cut to fit kinda thing. (I was able to get the vibration dampning style u joint for the box as mentioned by Rocknrod.) One U-joint alone will correct and angle but you'll need two to fix an offset. Borgeson's tech support helped me figure out what part numbers to buy and then I got them from Summit. Total cost not counting the 67-72 column was less than 300 bucks. Its your steering....fix it once and fix it right.
AcampoDave is offline   Reply With Quote
