Old 02-05-2020, 01:43 AM   #1
Dodge68charger
Battery Charging?
Is There a Correct ProcedureTo Test My Truck Battery To Make Sure Its Charging? Thank You
Dodge68charger is offline   Reply With Quote
Old 02-05-2020, 02:01 AM   #2
randy500
Re: Battery Charging?
Volt meter, check voltage not running and then running.
More than 14 volts running is usually standard. 12.6 to 13 not running is fully charged, i believe, there are charts for this
Clip on ammeter works too, kind of specialized equipment though, i have a very old plastic ammeter that you place close to the charging wire and it moves with direction of current travel.
randy500 is offline   Reply With Quote
Old 02-05-2020, 11:52 AM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Minimum charging voltage is 13.5V, but can be as high as 14.5V when running. Above that, you risk getting the battery too hot. 12.6 is a fully charged battery. Here's a link to Battery University- https://batteryuniversity.com/ Probably more than you ever wanted to know about batteries.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
