Bracket kit for Alternator, PS pump and AC compressor?
Is there a good bracket kit available for the 235 that offers everything needed to support alternator, power steering pump and AC compressor on the 235?
I presume another crank pulley will also be needed?
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
Re: Bracket kit for Alternator, PS pump and AC compressor?
Davis speed equipment is the go to supplier for the brackets for 235 and other six cylinders. https://davisspeedequipment.com/
They have several possible combinations/options to accomplish it depending on your preference or space.
I used Davis Speed Equipment for my AC brackets. They fit right and mounts the AC on the right side of the engine. The brackets I used for power steering and alternator were made by an individual who no longer makes them. I used him because his kit mounted the alternator above the power steering pump. You definitely don't want the PS pump above the alternator in case it leaks.
Nice setup there. I Like it that Davis gives you a few options to pick from. I've been looking at their pieces for my 292 but like the vintage air 292 compressor bracket better because it mounts the compressor lower.
#5 | |
Davis speed equipment sells on Ebay. The prices are the same but it may possibly simplify things on your end.
