Brothers frame kit problems
Just finished the Brothers frame shortening kit on 66. As referenced in other threads, the measurements for the cab mounts are 1/2 inch off. I read this before I started and thought, well maybe they fixed it. Nope. If you try this kit, cut the cab mount off per the instructions, then wait until you’ve got the frame pushed together and bolted to relocate the rear cab mounts. Left a review on Brothers blog, and they deleted it. I don’t think that will fix the template!
Re: Brothers frame kit problems
Hmm, interesting. Your cab won’t bolt up to the cab mounts? I used their kit a few weeks back and my stuff bolted up.
![]() Join Date: Feb 2014
It was the tape measures fault happens to me all the time
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
#4 | |
Yep, wouldn’t line up, hogged out frame mount to get the bolts in
I use the Stacey David method better engineering for the welding...
