Old 02-05-2020, 07:57 PM   #1
kmswi
.005 oversize rings on std piston ? SBC
I have an engine that sat with water in the cylinders causing some pitting, honed it to clean up, was rebuilt recently with std pistons, I don't have a bore gauge but measured ring end gaps and they seem a little wide, .028, Should I try to find some .005 oversize rings? Daily driver not a race vehicle.
kmswi is offline   Reply With Quote
Old 02-06-2020, 08:49 AM   #2
JMac11
JMac11's Avatar
Re: .005 oversize rings on std piston ? SBC
If you are that curious, buy a set for one piston and check the cylinders at bottom of ring travel. I suspect the gap will be overlapping. A gap of .028 on a rering should get ya going for a while, but it is not going to be perfect.
JMac11 is online now   Reply With Quote
Old 02-20-2020, 10:25 AM   #3
gafiredog
I have a 350 block that got some water in it and caused some pitting, I tried to hone it, but did not get all the pitting out. wouldn't the pitting cause it to burn oil? and not hold correct compression?
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 02-23-2020, 02:16 PM   #4
Wikid61
Wikid61's Avatar
Need maximum results? Stop guessing and research basic 350 sbc builds. Boring the worn, damaged block w/a torque plate will ensure the bores are straighter than factory. Smoother running, more efferent. Patch it and go, or save up and have a far better engine.
Wikid61 is offline   Reply With Quote
