Old 02-06-2020, 06:45 PM   #1
jmader
jmader's Avatar
Is this an Original 1968 K10 Power Steering Setup?
Just picked up this anniversary K10 a couple weeks ago and never even noticed until today that it has power steering. It’s not listed on the SPID. Is it original?
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 02-06-2020, 10:25 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Is this an Original 1968 K10 Power Steering Setup?
Don't know about the original part but it looks like mine. Mine is a 68 but it's not original either.
I know the 67 had the power ram assist instead of the steering box. Check out this link on it.
I have the whole thing out in my shed of parts I took off my 67 when it burnt up. Never did like it and it leaked like crazy as in the thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=253657
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-06-2020, 11:31 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
That looks correct to me. 68-69’s (maybe even 70) don’t have the adjustable drag link like the later trucks do. You also have the older style steering arm on the knuckle. I believe power steering became standard equipment on the 4wd trucks thus not included on the spid. However that axle isn’t original, it should have a closed knuckle 44. Hard to tell from the pictures, does it still have front drums? If so, that is likely a ‘70 axle. That is a really nicely optioned anniversary K10! Nice score!
Tyler
57taskforce is offline   Reply With Quote
Old 02-07-2020, 12:48 AM   #4
Classic v6 GMC's
Classic v6 GMC's's Avatar
Might be a dumb question but why does the spid have posit traction listed twice with different option numbers? Is that for front and rear axles? Looks like a nice optioned truck!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 02-07-2020, 02:52 AM   #5
Jcfcamaro
Jcfcamaro's Avatar
Everything looks right, but the pump. Its newer ,but it will work.
Jcfcamaro is offline   Reply With Quote
Old 02-07-2020, 08:38 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The pump is a later model perhaps square body style. Since not listed on SPID it’s doubtful a factory power steering equipped truck.
Old 02-07-2020, 08:42 AM   #7
Bigdav160
Bigdav160's Avatar
The '68 Information kit from the GM heritage site doesn't show power steering as being standard. It also doesn't even show it as an option on 4x4.
It's one of those unicorn things. There have been a couple pictures of 67-68 4x4 with PS (ram/slave) but to me, the frame in those pictures, doesn't look like a pickup frame.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-07-2020, 08:46 AM   #8
jmader
jmader's Avatar
I think that's what it is. I was going to research it but haven't gotten around to it yet.
1967 Chevy SWB K10
Build thread-
Old 02-07-2020, 08:48 AM   #9
jmader
jmader's Avatar
Yes it has drums. Does not have closed knuckle. I thought that ended in 1967?
1967 Chevy SWB K10
Build thread-
Old 02-07-2020, 08:52 AM   #10
jmader
jmader's Avatar
Would a 68 have a VIN on the frame to verify this?
1967 Chevy SWB K10
Build thread-
Old 02-07-2020, 08:55 AM   #11
jmader
jmader's Avatar
That's what I was thinking but it looks original to me besides the pump. I've seen SPID's from newer trucks that list the power steering as an option.
1967 Chevy SWB K10
Build thread-
Old 02-07-2020, 09:04 AM   #12
68panelman
68panelman's Avatar
Yep, axle is a 1970 only model, which is fine, drums are still available, 3/4's are obsolete. But that OE front posi would of been sweet. Nicely optioned rig, any pics of the entire truck?
68panelman is offline   Reply With Quote
Old 02-07-2020, 09:14 AM   #13
jmader
jmader's Avatar
How can you tell that’s what the axle is just by looking at it? Here’s a link to some pictures of the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=800176
1967 Chevy SWB K10
Build thread-
Old 02-07-2020, 09:16 AM   #14
68panelman
68panelman's Avatar
Close knuckles last year was 69.
1971 introduced front disc brakes as standard equipment
Old 02-07-2020, 09:20 AM   #15
jmader
jmader's Avatar
So the power steering setup is probably from that 1970 truck?
1967 Chevy SWB K10
Build thread-
Old 02-07-2020, 09:23 AM   #16
Andy4639
Old member
Andy4639's Avatar
The power steering could be a 71 are 72 pump. They could have swapped the tank on to the pump. Who knows for sure. The over all unit is the correct type of power steering parts though.
Old 02-07-2020, 09:53 AM   #17
57taskforce
All about them K’s
Thanks for clearing that up. I always seem to learn something new every day here. I went a looked at a pic of my K20 spid and sure enough its got power steering listed. Maybe I was confusing power brakes and power steering. I know mine has no mention of power brakes on the spid but it definitely had them. It’s got hydraboost now.
Op, closed knuckle was last used on the ‘69 trucks.
You can tell it’s a ‘70 axle because ‘70 is a one year only with open knuckle drum brakes and red hub dials. ‘71+ are all open knuckle disk.
Tyler
Old 02-07-2020, 01:18 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The pump tank is definitely post-72. Here's a diagram given to me by Marty at PowerSteering.com that shows a correct Saginaw pump for 70-72 K applications. The boxier style you have came after. How do the fittings compare?
Old 02-07-2020, 03:09 PM   #19
cypressbog
Go Pack Go!
Board member 67-72chevytrucks has been looking for a power ram assist for his 68 anniversary SWB 4X4 for a number of years. I'm not sure if he found what he's looking for, but that may be what came on the 68 4X4 trucks?
cypressbog is offline   Reply With Quote
Old 02-07-2020, 04:20 PM   #20
jmader
jmader's Avatar
I remember that WTB thread and I did a quick search for it but didn’t have any luck. Maybe I didn’t use the right search words.
1967 Chevy SWB K10
Build thread-
Old 02-08-2020, 05:10 PM   #21
Andy4639
Old member
Andy4639's Avatar
I have the whole system off my 64 SS Impala. Less the pump. It's basically the same thing. I put a normal power steering box on the 64. It's more reliable and much cleaner looking and want drag on things.
