Old 02-07-2020, 03:16 PM   #1
chero
Wiring harness modify
Have 68 C10 doing LS swap. Have engine harness and ecm from 06 Tahoe. Salvage cut up harness. Was non flex harness. Bought replacement harness. From 05 1500 but turned out was flex fuel. Question is, can I use flex harness and ecm by replacing pigtails from old harness. Wire colors on both harnesses same. Assume I'd use flex ecm. Any ideas. Thanks for any help!
chero is offline   Reply With Quote
Old 02-07-2020, 03:30 PM   #2
prodjay10
Re: Wiring harness modify
Yes. You gotta let the tuner know they are different injectors since the flex and non flex have different flow rates.
Or you can get the flex injectors.
prodjay10 is offline   Reply With Quote
