02-08-2020, 04:41 PM | #1 |
help i.d. a bracket
need help identify this bracket please
72 c10, I think it goes under the dash somewhere but I dont know for sure. any help would be appreciated thanks |
02-08-2020, 05:30 PM | #2 |
Re: help i.d. a bracket
Looks like the brace for the power brake booster.
02-08-2020, 05:34 PM | #3 |
Old member
x2 brake booster bracket.
02-08-2020, 10:21 PM | #4 |
are there 2 brackets on the booster?
I already have 1 that's a wide C channel that goes from the outside (left) master cylinder to booster stud and down to the left of the column on the firewall. this bracket is a round bar bracket. |
02-08-2020, 10:55 PM | #5 |
Here a picture from the forum.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
02-08-2020, 11:00 PM | #6 |
Junior Member
One to the side and one underneath as I recall. Although when i switched to the smaller diameter booster I could only use one of them.
02-09-2020, 12:29 AM | #7 |
ah, yes bolted under the top parking brake mount.
THANK YOU ALL |
