Old 02-08-2020, 08:17 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Replacement woodgrain for bezel?
Is there anywhere you can buy just the woodgrain sticker? Has anyone redone their bezel themselves and used a specific product? What was the product/procedure/result?
Thanks!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Ryan Brown Performance 850 Holley
Full weight long box pickup
Current best- 11.28@119mph
69GMC910 is offline   Reply With Quote
Old 02-08-2020, 11:51 PM   #2
Bandit130
Bandit130's Avatar
Re: Replacement woodgrain for bezel?
Thanks!
I thought about doing this myself. I looked online and even went to Lowes to look at the wood grain laminate they have in rolls but decided not to. Putting the stick on laminate would be a hard detailed process. It could be done, but I'm probably not that good at that type of detailing. So, decided not to attempt it.
Good luck.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 02-11-2020, 07:41 PM   #3
65chevysub
65chevysub's Avatar
Following this thread as I want a wood grained interior
65chevysub is offline   Reply With Quote
Old 02-12-2020, 01:24 AM   #4
ShortHaul
ShortHaul's Avatar
This is what I've seen being recommended.
https://www.3m.com/3M/en_US/company-...94857497&rt=r3
Have not used it personally, so can't comment on that, but I've seen other folks vouch for it on here.
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 02-12-2020, 12:01 PM   #5
69GMC910
MOTORHEAD!
69GMC910's Avatar
Anybody know what the correct wood grain in the 3m Di-Noc would be?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Old 02-12-2020, 05:43 PM   #6
Eyegore
What Hump?
Eyegore's Avatar
Do not know about the 3m product but here are some ideas for vinyl wood grain wrap that might work:
https://www.customautotrim.com/vinyl...in-vinyl-wrap/
https://www.youtube.com/watch?v=sSNSsqHJ0uk
https://www.youtube.com/watch?v=fhj3yAbEbAw
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 02-12-2020, 06:51 PM   #7
ray_mcavoy
I'm not sure if any of the 3M offerings are direct matches or not, but according to the factory sales literature, there were 3 different simulated wood grain finishes used for the dash bezels and other interior trim from 1973 to 1977.
1973 - 1974 = Dark Walnut
1975 - 1976 = Burlwood
1977 = Chestnut
The wood grain was replaced with a brushed metal finish in 1978 that continued up into the 80's.
They went back to a wood grain in some of the R/V series around 89 or so but I don't remember seeing any specific name for it in the brochures.
ray_mcavoy is offline   Reply With Quote
Old 02-12-2020, 07:18 PM   #8
69GMC910
MOTORHEAD!
69GMC910's Avatar
1977 = Chestnut
Thanks Ray!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Old 02-14-2020, 06:23 AM   #9
Danmcg
Thanks for the links Eyegore!
Danmcg is offline   Reply With Quote
