Old 02-09-2020, 04:23 PM   #1
Rondarado
04 Yukon Heat Stuck On
Ok guys and gals, I'm stumped.
2004 Yukon with the drivers side heat stuck on. I've replaced the climate control module (digital dual zone) twice and 2 blend door actuators. I've done the recalibration process countless times and I still only have heat on the drivers side. The passenger side adjusts just fine. I've left the actuator out so I can just turn the blend door by hand so I know that it hasn't fallen down. I'm stumped and tired of constant 90 degree heat.
Rondarado is offline   Reply With Quote
Old 02-09-2020, 06:50 PM   #2
Re: 04 Yukon Heat Stuck On
I believe with yours there is 3 actuator for blend doors. Maybe the one you didn't change is the culprit. I hated messing with those buggers.
