Old 02-09-2020, 05:58 PM   #1
evan396
1966 k20 cab mounts
Any suggestions on cab mounts for a k20, I had the rear cab mounts redone and put them back on the frame, can't seem to find any for a k20. Was wondering if k10 or even c series would fit.Name:  20200207_200504.jpg
evan396 is offline   Reply With Quote
Old 02-09-2020, 09:01 PM   #2
raylube
raylube's Avatar
Re: 1966 k20 cab mounts
If you are talking about the front mounts I used the polyurethane ones from energy suspension that come in a kit with all four they do not list a 4wd option but they work just fine except the rear bolts are bigger and you have to remove the cage nuts even on the 2wd. The back ones on mine have the normal 1/2 ton variation
One of the vendors sells the rear mounts so you can use the normal cab mounts and not the shear design
raylube is offline   Reply With Quote
Old 02-10-2020, 08:16 PM   #3
evan396
Thanks ray.
