Old 02-10-2020, 10:38 AM   #1
jmader
jmader's Avatar
A/C Heater Valve Mounting Location?
I’m adding factory A/C to my truck and can’t figure where to mount the early style of valve. Is there some kind of bracket that mounts to the inner fender for the early style? This is the style that I’m using.
I’m wondering if it mounts on this clamp somehow? The clamp too small to fit the heater hose though.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 02-10-2020, 10:48 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: A/C Heater Valve Mounting Location?
I don't have a pic but it mounts to the passenger inner fender
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-10-2020, 10:53 AM   #3
jmader
jmader's Avatar
I’ve found a few pictures of the newer style mounted to the inner fender but they have a bracket already attached to them so they’re easy to mount. The one I have doesn’t have a bracket and I searched all over the parts board going back several years and didn’t find a single bracket ever offered for sale.
1967 Chevy SWB K10
Build thread-
Old 02-10-2020, 01:10 PM   #4
sick472
sick472's Avatar
jmader,
Do you have to stay Chevy stock?
Will it be cable, vacuum, or electric controlled?
I don't know much about the original GM heater control valves, but there are many aftermarket valves available that come with brackets OR I have used Pipe Clamps of various styles to fasten hoses to inner fenders/firewalls/under dash sheet metal/etc that could possibly work for you.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-10-2020, 02:10 PM   #5
tdangle
tdangle's Avatar
Oreilly auto parts Murray Climate Control Heater Valve Part # 74610. This one has the bracket built in. $29.99
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-10-2020, 02:46 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Since a pic is worth a thousand words:
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 02-10-2020, 03:52 PM   #7
FirstOwner69
FirstOwner69's Avatar
Stocker's picture shows the later style valve. I think that was used starting in 1970 or 1971.
The early style valve (yellow circle in the picture below) was not directly attached to the inner fender. There was what I'd call a band type bracket/clamp (red circle in the pic) that attached to the inner fender 2 or 3 inches toward the firewall from the valve. The clamp secured both heater hoses to the inner fender and, as a result, kept the valve from moving.
Sorry about the pic. It's a maze of hoses there and this is the best shot I have on file.
FirstOwner69 is offline   Reply With Quote
Old 02-10-2020, 04:26 PM   #8
FirstOwner69
Here's a shot showing how the clamp is used that you asked about in your first post.
Old 02-10-2020, 04:36 PM   #9
tdangle
tdangle's Avatar
Firstowner69 is correct, I have a 70 and the valve is attached to the inner fender. I didn't know earlier models had it basically free floating. Either should work just fine.
Terry
Old 02-10-2020, 04:36 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
For at least the 72 MY there are dimples in the RH inner fender that serve as a point of attachment for the valve in AC equipped trucks. Here's how the valve was affixed in my blue 72 Blazer (last pic shown in link): http://67-72chevytrucks.com/vboard/s...5&postcount=56
Old 02-10-2020, 04:42 PM   #11
FirstOwner69
A pre-restoration picture.
Old 02-10-2020, 05:30 PM   #12
FirstOwner69
This is what is used with the early style valve to attach the hoses to the inner fender.
https://www.classicindustries.com/sh...rch/?q=3770259
EDIT: 3770259 is the GM part number. Readily available.
Old 02-10-2020, 05:59 PM   #13
dmjlambert
dmjlambert's Avatar
That's what I have on my 69 truck. The hose clip holds the hoses and the vacuum line, and the heater valve just sits there on the fender at the end of the hose just like FirstOwner69 shows in the pre-restoration picture.
dmjlambert is offline   Reply With Quote
Old 02-10-2020, 07:35 PM   #14
jmader
jmader's Avatar
Thanks for all the info guys. I was hoping I could just let it kind of free float rather than have to track down a bracket. I have one of those that FirstOwner linked and that’s what I kind of was planning to use.
1967 Chevy SWB K10
Build thread-
Old 08-10-2020, 11:22 AM   #15
EagleChief
EagleChief's Avatar
I know I'm a little late to this party, but thought I'd join in anyway. I'm now dealing with this same issue and found that RockAuto has 2 of these listed under the '71 year with a bracket that is already attached.
https://www.rockauto.com/en/moreinfo...8g4VuGgAWxZe1a
Hope that link works... Just in case, I'll attach the picture I have of it.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
