Old 02-11-2020, 10:59 PM   #1
66clow
66clow's Avatar
Front Sway bar for a 5 7 drop?
Looking for a sway bar for my 69. It has a 5 7 drop. How do I know what will fit? What are you running? Thanks
66clow is offline   Reply With Quote
Old 02-12-2020, 10:32 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Front Sway bar for a 5 7 drop?
Call Dennis of Dennis Chevy truck parts in Pinellas park and see if he has a stock front sway bar then just order a set of the front sway bar mounts for dropped trucks .
Here's a good thread from Tx firefighter http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
https://www.google.com/search?client...6330463820;mv:[[27.865755777319023,-82.73237401648193],[27.865395822680966,-82.73278118351809]]
https://www.classicparts.com/1963-72...xoC5pMQAvD_BwE
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-12-2020, 10:41 AM   #3
Jcfcamaro
Jcfcamaro's Avatar
A factory bar will work but you will need to buy the lower/ smaller mounting bracket that mounts on the underside of frame.
Jcfcamaro is offline   Reply With Quote
Old 02-12-2020, 10:54 AM   #4
Jcfcamaro
Jcfcamaro's Avatar
It's been years since I did the same drop on my 72 and never took it to the alignment shop to get it finished but ended up buying a 72 k10 and have been working on it ever since. All the lowering parts came from McGaughys but not positive on the frame bracket. Here is a 69 factory sway bar I was going to use. The diameter is 1 1/16
Old 02-12-2020, 11:13 AM   #5
Grumpy old man
Here are the brackets and bushings for the 1 1/16 stock front sway bar . They have the grease fitting so the urethane bushings don't squeak
https://www.ebay.com/itm/Energy-Susp...EAAOSwGUhc1uEu
Old 02-12-2020, 01:54 PM   #6
Metaldoc
Metaldoc's Avatar
1985 chev truck sway 1 1/8 with lowered brackets, rear 1" sway custom made. I really need to clean, it's not so shiny side down
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 02-12-2020, 04:21 PM   #7
michael bustamante
michael bustamante's Avatar
I pulled a 1 1/4" sway bar of a square 3/4 ton and no problems. My truck is also lowered and I just ran the bar thru the INSIDE of the frame mounts. worked perfect. no need for flattened out aftermarket frame mounts
1967custom
michael bustamante is offline   Reply With Quote
Old 02-13-2020, 02:14 AM   #8
PepperTreeGarage
PepperTreeGarage's Avatar
1 1/4" '73-'87 "Square Body" sway bar. I believe that the 1 ton dually up to '91 is also a fit. I bought one out of a salvage yard and upgraded from the 1 1/16". Main reason was the previous owner installed a 1" bar in the rear. Rear of truck is leaf spring. 5/7 drop on our C20.
PepperTreeGarage is offline   Reply With Quote
Old 02-13-2020, 12:14 PM   #9
sprint_9
sprint_9's Avatar
Mine front bar came off a late 80s dually, it was an 1 1/4.
No Limit on the back.
sprint_9 is offline   Reply With Quote
Old 02-13-2020, 04:43 PM   #10
PepperTreeGarage
Nice. The rear sway bar was on the truck when I got it. It's an old Hellwig 7402 that was in rough shape.
