Old 02-12-2020, 02:33 AM   #1
60chevyc10
60 Chevy c-10 upper control arm
Dose anyone know if there is a way to replace only the upper control arm on the 60-62 c-10 with a tubular control arm for possibly better drivability ? Thanks
60chevyc10 is offline   Reply With Quote
Old 02-12-2020, 08:37 AM   #2
PGSigns
PGSigns's Avatar
Re: 60 Chevy c-10 upper control arm
The geometry doesn't change so the swap will not improve the drivability. A good alignment with more caster than the stock settings will help. If you can get 3 or 4 degrees it really helps. There is a caster mod thread in the suspension section that may not work on yours but a good read. There is also the make it handle thread thats is very long but covers a lot of what improves the handling.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-12-2020, 11:23 AM   #3
SkinnyG
SkinnyG's Avatar
If a tubular upper arm positions the balljoint back a bit, you'd get the extra caster you want.
The lower arms cannot be easily moved forward for caster like the 63+ can.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
