Old 02-12-2020, 07:04 PM   #1
Rogerlumibao
Windshild Wiper pump replacement
So after having issues with my pump and didn't want to do all the work (with AC) and didn't really care about rebuilding old one . So I also went to napa and bought their universal kit. Ran wires from ground to pump, power side of pump to to a push button under dash, the other side of switch to fuse under ignition on fuse box. Works great maybe too well and had to readjust the nozzles. Total money spend 40bucks with pump kit, extra wire, switch, bracket, and 7 feet of hose
Rogerlumibao is offline   Reply With Quote
Old 02-12-2020, 08:36 PM   #2
Daron65
Re: Windshild Wiper pump replacement
I think I will be doing basically the same thing soon.
I like the switch idea.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350
1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job
1953 Buick Special. GM 355. Just a good smooth engine.
Daron65 is offline   Reply With Quote
Old 02-12-2020, 08:49 PM   #3
3757chevy
3757chevy's Avatar
I ran a Universal pump off the yellow and blue wires going to the original pump and my OE wiper switch runs the new pump . I did it to my '67 and my K5.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-12-2020, 08:52 PM   #4
franken
I have an S10 res w/ the pump on it somewhere and was planning to wire that to the original connection on the wacky factory pump. The S10 res is larger.
franken is online now   Reply With Quote
Old 02-12-2020, 09:46 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Windshild Wiper pump replacement
Do your self a favor. Go to the local pull yard and get the spray nozzles off a late model Tahoe are which ever and put them on the wiper arms. You can thank me later. Get a full swipe of the water and it cleans the window much better.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-12-2020, 10:37 PM   #6
Rogerlumibao
That's an awesome idea !!
Old 02-13-2020, 10:34 AM   #7
Andy4639
Old member
Andy4639's Avatar
These are off the rear window of 99 Tahoe and up. Esclades and others all have them even the ford's SUV's have them.
Old 02-21-2020, 02:19 PM   #8
3757chevy
3757chevy's Avatar
New ones are available. https://www.napaonline.com/en/p/NDP6653058
MIKE
Old 02-21-2020, 11:10 PM   #9
Andy4639
Old member
Andy4639's Avatar
I also ran my electric pump off of the original switch. No need for the under dash stuff.
Old 02-22-2020, 12:56 AM   #10
mikecaddy500
mikecaddy500's Avatar
Smile Re: Windshild Wiper pump replacement
Get the washer bottle too... It has the pump inside the tank.
mikecaddy500 is offline   Reply With Quote
