02-14-2020, 12:53 PM | #1 |
Are you painting your truck ?
Well I'm pretty sure we all hate opening and closing let alone stirring paint and primer cans , Not to mention the mess that goes with pouring out of gallon cans and cost of wasting supplies , I've got multiple panels to shoot over a couple days . Check these out .
https://www.youtube.com/watch?v=QWeLVJrS1f0 https://www.youtube.com/watch?v=jZ0iG6XXzBA https://www.rockler.com/mixing-mate-...SABEgJ7MPD_BwE
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-14-2020 at 06:41 PM. |
02-14-2020, 01:39 PM | #2 |
Re: Are you painting your truck ?
Yes these are great to have around I normally have a few in different sizes in use and keep the job clean and neat.
02-14-2020, 01:46 PM | #3 |
Thanks! Just purchased one, as I too have a bunch of painting coming up. Question, what are you using to clean this with after the fact?
02-14-2020, 01:54 PM | #4 |
I'm going to clean it up with some reducer ,But considering how expensive paint is and how easy these are to use I'm buying 2 to get free shipping , if they don't clean well for $20.00 I'll just toss it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-14-2020, 02:00 PM | #5 |
Thanks for that link. They're $13+ each cheaper than on Amazon. And since I'm not in a hurry, that's a good savings. Ordered 2 as well.
02-14-2020, 02:06 PM | #6 |
Like it,
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
02-14-2020, 02:13 PM | #7 |
Looks promising. Maybe an extra gallon can, put in pint of reducer. After cleaning, the reducer is saved for your paint mix, your going to strain it anyway...Last gallon of reducer was $40.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
02-14-2020, 02:25 PM | #8 |
I'm giving one a shot as well. With the cost of automotive paint, you can easily spill more than these gadgets cost.
02-14-2020, 02:31 PM | #9 |
The info says it works with water or solvent based finishes - specifically, will it work with lacquer? MICHAEL B on Apr 8, 2015 BEST ANSWER: I had no problem with lacquer based paint or conversion lacquer. Cleaned up easily and did not seem to soften plastic. left on can for 4 days. not sure if i would leave on for extended periods but clean up was easy so not a problem. Will it hold up to lacquer and lacquer thinner? Joel S on Nov 19, 2017 BEST ANSWER: I use mine with lacquer, it's been in the can for several months and now in its second can. Doesn't seem to be any problem. I have two gal. And a quart. Gonna order some more
02-14-2020, 03:31 PM | #10 |
The timing of this discovery, for me, is most unfortunate...I just finished up the painting portion of my truck...UHHHHG!
I think it's a fantastic find and most affordable too. Makes me look forward to painting again. I have been using spray bomb lids and a hanger wire handle to dip my paint out of the can as I rarely paint more than a couple guns at a time.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
02-14-2020, 04:33 PM | #11 |
One of each size for me as well, thanks for the link.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
02-15-2020, 10:14 AM | #12 |
I would wash that thing before I stuck it in a can. Clean up could prove costly, time wise and tedious. Gadgets are always good, things and tools always lead to development to better processes. As with anything figuring out how to use them is the key.
