Old 02-15-2020, 09:20 AM   #1
Pontitruck
Pontitruck's Avatar
Which Power Steering Hose?
Hi guys,
I have a 2005 5.3 and stock pump in my 65. The gear looks like an 80s style with metric fittings. What hoses work with this set up?
Pontitruck is offline   Reply With Quote
Old 02-15-2020, 10:20 AM   #2
bigmoe
bigmoe's Avatar
Re: Which Power Steering Hose?
Originally Posted by Pontitruck View Post
Hi guys,
So the pump is 2005? There is a fitting on the back of the pump that takes a 1" wrench to remove. That fitting can be exchanged for one from an older pump that has the right size thread to match your steering box. You have 2 fittings to choose from and need to match your steering box. You can source one from a wrecker but they also sell aftermarket ones. I assume you have a power steering box from a square body? What year is the box because there are two different size fittings. I think they changed around 81.
bigmoe is offline   Reply With Quote
Old 02-15-2020, 10:32 AM   #3
Gregski
Post Whore
Gregski's Avatar
bigmoe is spot on I am just adding pics for a visual for you
Gregski is offline   Reply With Quote
Old 02-15-2020, 11:14 AM   #4
Thealien
Thealien's Avatar
It is interesting. I posted about this in the LS swap thread back in 2009.
Hard to believe it has been this long?
THIS THREAD HERE
Thealien is online now   Reply With Quote
Old 02-15-2020, 03:10 PM   #5
LS short box
I like using -6 Teflon lined SS hose on the pressure side. You will need a -6 adapter for pump o-ring if its a LS pump. A 90 degree -6 fitting out and down to the steering box and -6 adapter and 90 degree fitting into the box. About 2 feet of -6 line? on the pressure side. Not real expensive. You can reuse the low pressure return cut to fit as needed.
LS short box is offline   Reply With Quote
Old 02-15-2020, 10:45 PM   #6
truckdude239
truckdude239's Avatar
I swapped the fittings 9n my 71 I got the fitting valve and spring out of a 72 Chevy van and swapped it into my 04 pump and used the standard 1971 c10 power steering line way earlier to get a replacement hose and not having to get a custom hose maded
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-16-2020, 10:01 AM   #7
Pontitruck
Pontitruck's Avatar
Thanks for the replies guys. I think what you are all leading me to is changing the 5.3s pump to SAE type of fittings if my gear matches. I'll look today but believe my gear is metric too so then the pump and gear would match, are there pre made hoses that I can purchase or do I need to make something?
Old 02-16-2020, 01:42 PM   #8
bigmoe
bigmoe's Avatar
If your steering box is the later metric model I wonder if you could make an 05 hose work? Maybe snag one cheap from a wrecker first to try. Your other option would be -an fittings and hose. Looks nicer but that way adds up. I bet someone has some left over hose you could use.
The low pressure hose should be easier to just get from an 81+ C10.
Old 02-16-2020, 01:48 PM   #9
prodjay10
Get the fittings from the hoses you have, buy some hose sold by the foot from the parts store, and buy some single or double ear hose clamps, and make your own.
prodjay10 is offline   Reply With Quote
Old 02-16-2020, 01:56 PM   #10
Pontitruck
Pontitruck's Avatar
This is what it looks like, it Oring metric I think. This is what happens when you buy someone else’s project. Lol
Old 02-16-2020, 02:03 PM   #11
prodjay10
Happens when you start your own projects too. That’s exactly the stuff I’d be posting about during my swap.
Old 02-16-2020, 10:25 PM   #12
Pontitruck
Pontitruck's Avatar
I ordered an '05 hose, will report back
Update- Stock 05 hose too long.
