Old 02-15-2020, 12:55 PM   #1
jaros44sr
jaros44sr's Avatar
clicking in front drivers side 4X4 hub
Started to work on front hub, assembled with original bearings, now I have a click at the 3 o'clock, tightened first locking nut with no change. PO was in here and ground the bearing seats some what. wondering what the fix might be, starting with bearings or replace spindle
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-16-2020, 10:30 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: clicking in front drivers side 4X4 hub
I may be stating the obvious here...if so forgive me
the first spanner nut is the bearing adjustment nut....it should not be "tight" as it sets the correct pre-load on the bearings.
The retaining washer....with all the holes...goes next to maintain the position of the first spanner nut.
Then the outer "locking" spanner nut goes on.....it should be "tight" ...it keeps the hub fastened to the spindle..
As for the grinding....I don't know....have a picture?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-16-2020, 10:42 AM   #3
litebulblsc
litebulblsc's Avatar
There is more information and pictures in his build thread
https://67-72chevytrucks.com/vboard/...10641&page=129
litebulblsc is offline   Reply With Quote
Old 02-16-2020, 12:36 PM   #4
jaros44sr
jaros44sr's Avatar
Obvious works for me, sometimes you can't see the forest for the trees...
I've adjusted the preloads in and out, repacked bearings(these are used), talked to a shop, that has 50 years experiance, followed the Chilton manual to a 'T', it says to back off first nut almost 90 degrees. still has a click.
So, you go back to the last thing you did, and I had rotors pressed on the hub, as I was laying the hub assembly on the ground, it didn't sound right, after further thought, I looked into the rotor, and it was loose on the hub, they used the old wheel studs, but it was only loose in one section.
Now I'm on the search for correct wheel studs, and have them pressed in to see if that is the problem. My first thought was brearings, since that would be the cheapest fix first, but the most obvious thing points to the wheel studs
The owner of the shop said the drivers side is the one he has seen the most problems with, since the rotation of the tire tends to loosen the spanner nut, he said to tighten the outside nut to 100 ft/lbs
SAFETY FIRST
AS usual, off topic
Jim
Old 02-16-2020, 01:20 PM   #5
jaros44sr
jaros44sr's Avatar
Thanks litebulblsc for posting up, wish I knew how to post a link
SAFETY FIRST
AS usual, off topic
Jim
Old 02-16-2020, 05:43 PM   #6
litebulblsc
Just a simple copy and paste.
Highlight the site address, "right click" on it and click copy, then paste that in the reply area
Old 02-17-2020, 10:58 AM   #7
jaros44sr
jaros44sr's Avatar
spent some time to bolt up wheel and tire(100 ft/lbs) torque, spun the tire and no click, so the answer was rotor was not seated, onto lock out and finish up drivers side
removed wheel and tire and no clicking
SAFETY FIRST
AS usual, off topic
Jim
Old 02-17-2020, 11:42 AM   #8
A1971Blazer
Glad to hear it was something simple...
1967 C10 Step side
1968 C10 Step side
