working cowl hood
does anybody have their cowl hood functioning ? I would love to see how you did it . you tube surprisingly only has a couple squarebody ones none I could find for ours . is it even possible with these I haven't seen the bottom of one of these hoods yet mine is on order now .
Re: working cowl hood
On 67-69 Camaros the cowl hoods have sheet metal ring as part of the hood assembly that feeds air from the back of the hood. The Camaro air cleaner has a bigger base with a small air cleaner and lid. Then a rubber seal around the base to seal it to the bottom of the hood. The only tricky part would be getting the air cleaner lined up with the bottom of the opening in the hood. Who knows if the hood supplier actually considered engine position when they built the cowl hood.
The cowl hood I put on my 67 does not have the Sheetmetal ring under side of the hood for the breather, it would require a lot of fabrication to make it work.Jeff
exactly why I was wondering if anyone has done it . I haven't seen the bottom side of hood or any pics of anyone who has made it work
im not against a little fab work if I can keep it from lookin too gaudy
