Old 02-15-2020, 05:44 PM   #1
FAKKY
Wiring Headlight Switch.
So looking at my harness (EZ wiring) and the switch (Factory FSM).
FSM says wires and locations
Tail Lamp
Dome Lamp
Dome Light
StopLamp
ParkingLamp
HeadLamp
But wiring harness wires are
Dimmer Power
High Beam Left
Low Beam Left
High Beam Right
Low Beam Right
Left Front Park
Left Tail Park
etc
Im not quite clear which of these wires cross over (function) ..... to the switch as for example Im guessing headlamp is for headlights - but how to link high and low beam into this ?
Also - what is a stop lamp ....... so on.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 02-15-2020, 06:29 PM   #2
FAKKY
Re: Wiring Headlight Switch.
Did these trucks have a high and low beam ......
or just a park and headbeam (regular) ....
Old 02-15-2020, 07:23 PM   #3
FAKKY
So think I mostly worked it out .......
Just not sure on this bit.
I *think* this is for a column that has a GM light switch for high beam etc .
So plug into column.
I dont think mine does (ididit).
https://www.ididitinc.com/i-25048738...tegory:1310139
So .... not sure what do do with these wires ....
  • Left High Beam and High Beam indicator (plugged together) 1 pin;
  • Dimmer PWR
  • Left Low Beam
So guess it comes down to
IS dimmer only for Dash/Gauges ? and hows is it controlled - did it exist in these years ?
LowBeam and High Beam headlight - how controlled etc.
Old 02-16-2020, 10:05 AM   #4
FAKKY
So ...... turns out this is the dimmer switch wiring for the dimmer switch control on the floor ..... which I had no idea about.
Old 02-16-2020, 10:33 AM   #5
Oldtruckwelder
Oldtruckwelder's Avatar
Been looking at different wiring options for my 1957 truck also.
Thinking it was on the painless wiring site under manuals for installing, appears that they supply a new dimmer switch for the floor with their package.
Neither less good reading to see the whole flow of their wiring kits.
JT from SC
Oldtruckwelder is offline   Reply With Quote
Old 02-16-2020, 03:37 PM   #6
mr48chev
mr48chev's Avatar
They all have to have a dimer switch unless you just plan to run low beams.
Floor mounted, column mounted or a toggle switch on the dash depends on your individual setup. Maybe I shouldn't mention toggle switch and add confusion. That would be more for a dune buggy style rig anyhow.
My ongoing truck projects:
Old 02-22-2020, 11:41 AM   #7
FAKKY
Installed the foot version ... works great - now just to mount it.
My switch loses power for park lamps when high beams are on ...... I assume thats normal. But tail lights get constant 12v in both low an high obviously.
Part of me was wondering should i just give the front park lights the same constant 12v as the rear tail lights in case my front lights ever fail.
Probably doesnt matter either way.
Old 02-22-2020, 03:27 PM   #8
Black_Sheep
Black_Sheep's Avatar
The tail light position on the headlight switch has dual terminals, I connected the park lights to the second tail light terminal so they would stay on with the headlights on. Works great...
Black_Sheep is offline   Reply With Quote
Old 02-22-2020, 08:56 PM   #9
FAKKY
Thumbs up Re: Wiring Headlight Switch.
Thanks - thats exactly what I was thinking
