Old 02-16-2020, 11:22 AM   #1
Rob 61 apache
Front shock bracket for 61 with 72 x member
I’m looking for ideas on how to put shocks in the front of my 61 apache with a 72 x member,the existing brackets don’t line up and are different widths,it has 2 inch lowering springs and 2 inch lowering spindles,with 350/350 trans(not sure if this matters)also what shocks are you guys using,(front and back)any help or pictures is allways appreciated !
Rob 61 apache is offline   Reply With Quote
Old 02-16-2020, 11:49 AM   #2
Getter-Done
Getter-Done's Avatar
Re: Front shock bracket for 61 with 72 x member
Here is a u tube video to explain how to find the length.
Link:https://www.youtube.com/watch?time_c...ature=emb_logo
Here is a link for custom shock brackets.
Link:https://www.speedwaymotors.com/shop/...6-31222?page=2
So I would determine what style shock you are wanting to go with.
(looks ,Performance or comfortable ride.)
Start with trying the find a shock that (Will fit) your existing lower mount.
Then find a top mount that will work with your mounting options on the frame.
Then try to find the correct travel length.
Main 3 things is diameter of mounting bolts, width of shock mounting bushing and length of travel.
Hope this helps.
The early bird gets the worm,
84 Chevy K-20
Old 02-16-2020, 12:00 PM   #3
LVPhotos
LVPhotos's Avatar
Here is Porterbuilt on 62. Pin top shocks. Some angle bar, a flat and welding
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
