![]() Join Date: Feb 2009
Dorman 13503 Lower Control Arm U Bolts - just drill out with a 9/16" Bit?
While searching other threads, I saw Dorman 13503 recommended. These are a lot bigger than the ones they're replacing.
Did you just drill out the saddle/crossmember with a 9/16" bit? Thank you
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
![]() Join Date: Dec 2009
Re: Dorman 13503 Lower Control Arm U Bolts - just drill out with a 9/16" Bit?
I would suggest drilling it 14mm (0.5512)
And then reaming it with 9/16 (0.5625) reamer. 14mm drill (link):https://www.homedepot.com/p/Drill-Am...-0MM/306365125 (9/16 reamer that could be used with 1/2 inch drill) Link:https://www.homedepot.com/p/Drill-Am...9-16/307840594 Or 9/16 reamer that would require a chuck that would accept 9/16 shank. link:https://www.homedepot.com/p/Drill-Am...3A%7B1%7D%3Anf Yeah you could probably drill it with a 9/16 drill Just be careful about breaking the edges off the twist drill. Link:https://www.homedepot.com/p/DEWALT-9...20-G/202579650 .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Getter-Done. I appreciate your advice. I will get the 14 mm drill bit and reamer. I'll be doing both our 67 C10 and 70 2wd Blazer.
Yeah, when I replaced mine I drilled em out with the 9/16" bit. It's a good safety upgrade.
72 C10 lwb fleetside -stock 350/350 combo |
Could you use a step bit?
I installed them today. I just used a 9/16th drill bit, because I couldn't get a 14 mm bit locally and didn't want to wait for a mail order one. Went pretty quick, and the new u bolts look a lot beefier.
Thanks for the advice.
I did this upgrade after I took a wild ride with a camper in tow.u-bolt broke and almost lost the whole rig.
68' with no bells or whistles unless I add'em. |
