02-16-2020, 08:57 PM | #1 |
Electric Fan recomendations
I have looked and looked at many fans for my 67 w/454 and end up with ziltch. I have 3 inches from pump pulley to radiator. Anyone here have the same distance and have found a fan with shroud that will fit?
Changing the water pump is not an option because of the serpentine belt system, and I'm leaving that alone. |
02-16-2020, 09:06 PM | #2 | |
The Older Generation
Re: Electric Fan recomendations
I will check mine tomorrow morning on the Panel Truck to see how thick they are. LockDoc
02-16-2020, 10:52 PM | #3 |
Maybe a trimmed factory late model big single unit?
I had a Lincoln MK8 fan on a 454 with short WP and it worked great. Maybe it would have cleared a long WP??
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-16-2020, 11:22 PM | #4 |
I went with the dual fan and shroud kit from Old Air Products for my 454 swap. It's a TIGHT fit. The water pump pulley actually sits between the fan motors, the alternator is above the passenger side motor, and the PS pump is below the drivers side motor.
Here's a link to the product I bought... https://www.oldairproducts.com/produ...hroud-assembly
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
02-16-2020, 11:31 PM | #5 |
Here is a dual fan setup that I am interested in....whenever I get working on my suburban again, I will have same problem as you...Vortec 454 w/serpentine system....
http://67-72chevytrucks.com/vboard/s...d.php?t=216128 |
02-16-2020, 11:55 PM | #6 |
Put a pusher on it, you should have room between the radiator and A/C condenser if so equipped. I have run both pushers and pullers with no issues.
02-17-2020, 10:59 AM | #7 |
As mentioned... the dual fan setup will place the thinnest portion of the setup at your pump snout. I went with the Champion dual fan shroud and 14" dual fans on my BBC with long pump and it fit nicely. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-17-2020, 12:17 PM | #8 |
Mine measure 5" overall thickness at the fan motors and 3 1/4" at the pump snout. The setup is off of a 2002 Camry. It fit great with minimal mods. At the top where it says "L" shaped mounting brackets they are actually "Z" shaped made out of 22ga metal 2 1/2" long. The fans cool great. The 2nd one very seldom comes on. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-17-2020 at 12:28 PM. |
02-17-2020, 10:57 PM | #9 |
Who Changed This?
I went to a 19" fan from Summit and made my own shroud to get my cooling problems under control. It turned out that the fan was too far into the shroud, no matter what clutch I tried, even the shortest available. I also installed a high flow thermostat. It runs cool (180º) in most conditions. It can run up to 200º when maneuvering the trailer into position with a lot of back and forth (I'm not that skilled with parking a travel trailer tight into the trees, yet). That's without running the AC, as it broke last year. It might get up to 200º pulling the trailer up a steep hill. It used to get up to 260º doing that.
I realize that this is not an electric fan recommendation, but I just wanted to share that an electric fan isn't always the solution.
04-17-2020, 12:58 PM | #10 |
Sorry for not responding. I have been locked out of the system since the day I posted this.
So, that being said, I went ahead and made my own shroud, and curious to what brand fans you guys feel are best for performance and reliability? 454 vortec with 4 core. But need fairly thin fans because of clearance. Thank you |
04-17-2020, 01:00 PM | #11 | |
04-17-2020, 09:43 PM | #12 |
Active Member
Has anyone tried fitting the f-body fan setup from a Trailblazer SS?
https://www.pcmofnc.com/product/ls1-fan-assembly/ I just checked the dimensions and it looks like it’s maybe too thick. Dimensions: 33x35x7 Reason I ask is that I have one that’s nearly brand new out of my recently wrecked TBSS. |
04-18-2020, 08:31 AM | #13 |
I bought an entropy radiator with the dual 16” fans. Had all kinds of overheating issues before. Since installing the system with my 462 BBC it runs no hotter than 185 degrees even during 100 degree summer days.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
05-03-2020, 07:32 PM | #14 |
I decided to build my own shroud. That's done, but now to find 2 fans. Summit probably has them but the way we have to get parts from them makes it tough to just look to see if they will fit. You have to order online or by phone and pay. Then you have to go there and sit in the parking lot and call to let them know you're there. Then you have to wait for someone to bring the parts out. If you don't have a cell phone...like me...you have to turn your flashers on. The guys running the parts just fly right by you without saying a word.
If what you buy doesn't work, you have to start all over again. |
