1 piece door glass?
Anybody out there have any luck with any 1 piece door glass kits for our Blazers? Everything i find says fits c10's, so i assume they will work, but trying to make sure of a decent kit. Thanks for any advice!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold) 1969 Jimmy, 2wd swapped. bagged, body dropped |
Re: 1 piece door glass?
It is not recommended to use with the Blazer doors
![]() Join Date: Jan 2001
It would be very difficult to keep them in place without a window run channel. Vehicles that have frameless windows usually have much more glass at the bottom of the window (the part below the door when the glass is rolled up).
Could you make it work? Probably, but to work well you'd have to fab something that would give you rigidity when the glass is rolled up.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
I appreciate your guys' responses! That was pretty much what i had thought, but figured a second opinion couldn't hurt. thanks
