02-18-2020, 04:19 PM | #1 |
OEM Windsheild
Is it worth getting an oem windsheild over a new replacement ?
Providing the oem unit is in good condition . Or is the gasket the primary concern for a good fit ? |
02-18-2020, 05:40 PM | #2 |
Re: OEM Windsheild
The repro gaskets are made for OEM windshields so they actually don't fit the new windshields well. Yes I would get it as they are thicker than new ones. I had to put a boatload of windshield sealer around my windshield to stop it from leaking (new Precision gasket and new windshield not OEM).
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
02-18-2020, 06:55 PM | #3 |
Re: OEM Windsheild
X2 on the NOS windshields vs OEM Aftermarket. New windshields are thinner and need sealant in the glass to rubber side.
I could imagine a NOS piece of glass is pretty much a unicorn. |
02-18-2020, 09:08 PM | #4 |
Re: OEM Windsheild
Has anyone use Pilkington glass classic. Glass ?
Per their web site the classic glass is made to oem stds ! |
02-19-2020, 07:06 AM | #5 |
Re: OEM Windsheild
^^^ That is the best replacement to get.
02-19-2020, 09:35 AM | #6 |
Re: OEM Windsheild
If you do get a thin windshield (compared to OEM) do yourself a favor and shoot a ton of 3M windoweld in there til it rolls out all the way around and then trim the excess off. I tried to be "gentle" with caulking mine and ended up unnecessarily battling the leak for a couple months as I swore that much water could not still be getting in the windshield from a leaking seal. It was like someone turned on a garden hose in my truck when it rained.
02-19-2020, 09:57 AM | #7 |
Re: OEM Windsheild
Pilkington bought LOF, one of the two OEM suppliers. They have a division for classic glass. I haven't used them yet, but I understand you can even get the LOF and correct date stamp for restoration work.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-19-2020, 03:38 PM | #8 | |
Re: OEM Windsheild
According to them , oem glass was 1/4” thick . What is a hair thick in there mind ? Glass price for a 70 c10 with 4” top tinted . $175. Shipping to me another $175. Last edited by mygmctruck1; 02-20-2020 at 08:22 AM. |
02-19-2020, 03:53 PM | #9 |
Re: OEM Windsheild
Just call your local auto glass shops and get quotes from them on the glass you want . Don't pay to have glass shipped .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-19-2020, 04:29 PM | #10 |
Re: OEM Windsheild
FWIW PGW was the glass I broke XYG is what the local glass shop brought for replacement ( not yet installed ) Didn't measure thickness but will later when they come back to install after I get the right gasket. EDIT: both are green tint blue sun strip, pretty sure the CCC in a circle means it's from China! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 02-19-2020 at 04:37 PM. |
02-19-2020, 04:51 PM | #11 | |
Re: OEM Windsheild
I have one, just replaced late last summer. It still will require 3M Window Weld in both Glass to Rubber side, and Rubber to Metal side. You will also need some CRL Problem Solver Nozzles most likely. Check this catalogue from CR Lawrence Company http://www.crlaurence.com/adv/catalo...dex.html?PN=18 Page 145 |
02-19-2020, 04:51 PM | #12 |
Re: OEM Windsheild
Not necessarily made in China, but the CCC mark is required for it to be sold in China. E1 means it's certified by Germany. The DOT mark is, of course, for the US. I'm not sure what the others are.
02-19-2020, 05:19 PM | #13 | |
Re: OEM Windsheild
02-19-2020, 05:22 PM | #14 | |
Re: OEM Windsheild
02-20-2020, 12:34 AM | #15 |
Re: OEM Windsheild
For what it is worth, Most folks on this website have all pretty much seen that new windshields are thinner than what came with the vehicle.
Precision is at the top of their class with these gaskets. So much so, that Steele Rubber products actually buys this particular gasket from Precision. I had that conversation directly with Steele Products via email. The DOT spec I am under the impression will tell you the thickness if you can decode the spec. |
02-20-2020, 08:31 AM | #16 | |
Re: OEM Windsheild
So then my new question is , if the oem windshield needs polishing ? How well does that work ? Providing there surface scratches . Found one the other day , not yet looked at it in person , so I am in hopes of getting this done soon. |
02-20-2020, 10:30 AM | #17 |
Re: OEM Windsheild
I have dabbled in glass scratch removal without much success. I concluded it best left for one with good experience in performing the task. This will likely cost more than new glass. The problem comes from using the proper glass specific polish (don't believe the web when it says toothpaste works) and a high speed buffing tool (to keep you from rubbing your arms off for the rest of your life). Where it gets sketchy is that heat will be built up during the process and to much heat in an area causes the glass to crack and you can't buff that out. I found that very, very light scratches that wold be seen as a haze could be improved, but the actual linear scratches that you commonly see where someone ran wipers without rubbers or hit the glass with a wire wheel are not coming out without leaving a wrinkle in the glass due to having to buff so deep to remove the scratch. This would be unacceptable for me considering how much time it would take to remove the scratch, the wrinkle itself, and the risk of wasting that time due to cracking the glass.
EDIT: Be aware that original or very old glass may have had the lamination separated around the edges. This is not too big of a deal until it draws moisture and the outer perimeter of the glass fogs up. I bought a used windshield many years ago that had, what appeared to be, nice antiquing along the bottom and sides that I thought I would use in my truck...after many years in storage the "antiquing" disappeared (or dried up). I have decided not to use it for fear that it would fog back up irregularly. I will be looking for the pilkington glass, precision seal, along with plenty of windshield sealer.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 Last edited by sick472; 02-20-2020 at 10:37 AM. |
02-20-2020, 11:36 AM | #18 |
Re: OEM Windsheild
The guy installing my glass is vintage and best in the business. He says point blank OER are thinner. If I remember right he uses various vendors, even for the same part.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-21-2020, 11:48 AM | #19 |
Re: OEM Windsheild
This is the XYG glass... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-21-2020, 12:46 PM | #20 |
Re: OEM Windsheild
02-21-2020, 01:33 PM | #21 |
Re: OEM Windsheild
I’ve read other threads and pilkington/precision was the answer to this issue. Anyways following this as this has always been a debating issue and maybe something new has come up.
02-21-2020, 01:44 PM | #22 |
Re: OEM Windsheild
What is the thickness of Pilkington glass?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
02-21-2020, 01:50 PM | #23 |
Old member
Re: OEM Windsheild
Even the manual says it needs sealer.
02-21-2020, 01:55 PM | #24 |
Re: OEM Windsheild
I still have the original windshield and gasket that came out of my '68, they used a heck of a lot more sealant that just the top corners.
02-21-2020, 01:57 PM | #25 |
Re: OEM Windsheild
How would this be done? Lift the rubber and squirt it in from the outside?
-klb
