![]() Join Date: Nov 2007
65 Towing a 69 Chevelle home
I bought a 69 Super Sport back in 1973. Towed it home from NC Saturday with my old truck. Lots of tongue load with the big block. I ran the air springs up to 140 psi and the tires up to 50 psi, pulled good.
The last pic is from 1975 wedding day. Time to restomod the 69.
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Re: 65 Towing a 69 Chevelle home
(I had this thread in the wrong forum and moved it here)
MikeN Replied: Sweet! I towed my 69 Chevelle to the drag strip once behind my 64 C10. Don't believe I thought to take a picture though. I also towed the Chevelle 150 miles home from the paint shop behind my 64 C10, now that I think of it. These old trucks tow good with a good trailer and hitch.
Very cool I love the truck and chevelles!!
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Damn. My favorite two vehicles. Very nice man
![]() Join Date: Oct 2006
Very Cool!!1
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Assuming disc brakes and air-bag type overload springs are common additions, does this era C-10 handle trailer towing relatively well?
Your truck appears to have a stock bumper, what are you using for a trailer hitch? |
While not 'ideal' 6X-87 C10's can more than get the job done on the occasional jobs. Air bags out back do help w/the squatting. Good brakes (all around including the trailer) are a need.....
What SCOTI said.
I have a Valley class 2/3 hitch which is solidly mounted to the frame. My rear suspension is all air, but 140 psi leveled the truck (normally run 80-100). The hitch is rated at 5,000# load, 500# tongue load. (With a weight distribution kit the rating is 10,000# and 1,000# tongue load. That mostly seems to just help level the load, which in my case the air bags took care of.) The big block engine and forward location on the trailer really put the tongue load high. Trailer has surge brakes and I have 4 wheel disc. Pulled fine down the interstate. My truck came with factory overload springs. I took them off because they were so brutal when they engaged. TR
| Bookmarks |
