Old 02-19-2020, 09:58 AM   #1
C.I.Blazer
PSI C10 DBW Gas Pedal
Anyone have any experience with this pedal from PSI? I am looking for a pedal for my '71 swap. Apparently this pedal has the equilateral bolt spacing of the newer trucks so I would have to make some type of adapter plate but am wondering about pedal positioning. My other option is to buy the truck pedal and get one of Hart Rod's adapters. I do not think I can go this route because of some modifications the PO made to the firewall (yes, with a hammer). Appreciate any help.
https://www.psiconversion.com/produc.../ACC-1049.html
C.I.Blazer is offline   Reply With Quote
Old 02-19-2020, 10:07 AM   #2
ls1nova71
ls1nova71's Avatar
Re: PSI C10 DBW Gas Pedal
Pretty sure that's just a diesel pedal. They can be had for way less than $100.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-19-2020, 10:20 AM   #3
C.I.Blazer
Thanks! I have seen reference to using the diesel pedal but a lot of the old links are dead. My understanding is that this would require me to rewire the plug for use with my Gen III 2004 LQ4. I guess PSI has already accommodated for this with their TAC harness.
Do you think this pedal will fit well in a 71?
Old 02-22-2020, 12:42 PM   #4
thehata1
Subscribed. Someone please post pics of installed pedal and range of motion.
I modified my pedal to work. But, it will give me a leg crap after about an hour of driving.
thehata1 is offline   Reply With Quote
Old 02-24-2020, 12:07 AM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I've got a new turbo diesel pedal that was going to be used in a gen5 swap but doesnt work with the pedal sensor values.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
