Old 02-19-2020, 10:09 PM   #1
conoco
conoco's Avatar
Temp gauge Question
My temp gauge was not working, it would just stay past hot. I changed the temp sensor and I also made sure there was power going to the green wire. I bought a new temp gauge from LMC that showed the actual temp in numbers instead of just H or L. When I took the gauge cluster out I noticed the back of the temp gauge looks like it should have a wire to one of the studs that come out. But there wasn't. Then I read the power for the gauge actually comes from the circuit board. I tested the circuit board and noticed that there was not power to some of the light connections and of course where the temp gauge goes. I just purchased a new circuit board from LMC and should be here soon. I needed it anyway the original one was very weathered. SO my question is on the back of the temp gauge is there a wire that is suppose to be installed? or does it get the power from the circuit board? Thank you for any help. If it does get power from a wire I am assuming its just the green one that is already hooked up to the sensor. Thank you.
conoco is offline   Reply With Quote
Old 02-19-2020, 10:25 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Temp gauge Question
Now wires. Only the tack has it's own wiring harness.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-19-2020, 10:52 PM   #3
conoco
conoco's Avatar
THANK YOU!! I was so confused, it just looked like a stud for a wire, thank you for helping me out.
Old 02-20-2020, 12:33 AM   #4
Andy4639
Old member
Andy4639's Avatar
My pleasure, that's why I'm here to help when I can.
