Old 02-19-2020, 11:31 PM   #1
CJ2A
CJ2A's Avatar
Where to get rear brake line ?
I need to replace the rear brake line on a 1971 K20. If I can find one longer than original would be ideal, the pickup has a 4” lift & the original line is tight and looks like the full 49 years of ware. The original line has a junction block that is fixed to the rubber line. I do not see the junction block in the parts photo’s of misc suppliers. The original line is 18” in length, 24” in length looks to be perfect for this lift kit.
Any suggestions ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 02-20-2020, 08:19 AM   #2
biketopia
Re: Where to get rear brake line ?
https://www.roughcountry.com/extende...sid=EXqdCd5cra
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 02-20-2020, 09:02 AM   #3
Willys_MB
Willys_MB's Avatar
That’s a stock part. I just replaced mine. They have lines that are longer. Check out rock auto.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 02-20-2020, 09:48 AM   #4
biketopia
The link I posted is an extended rear line for trucks with a 2-6" lift. Also if you have a hydraulic supply house near by most of them can make brake lines, you can give them the specs and they should be able to crimp you one up, although I've always found it cheaper to just order one from russel, or rough country, etc.
Old 02-20-2020, 11:14 AM   #5
rpmerf
rpmerf's Avatar
Here is a stock hose from one of our vendors.
https://www.classicparts.com/1971-72...ctinfo/71-365/
This is interesting. Rock auto images show the end as threaded instead of a T.
https://www.rockauto.com/en/catalog/...ulic+hose,1792
The main things you care about are the threads and the length. Wouldn't be surprised if you could grab one for just about any solid rear axle truck in the right length and have it fit.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-20-2020, 12:20 PM   #6
KMC3420
KMC3420's Avatar
Inline tube has a SS tube that is 24" long and is 3/8-24 on both the "T", and the connection to the frame hard line.
Inline tube 24"
T with mounting hole
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 02-20-2020, 02:13 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Where to get rear brake line ?
Buy a roll of tubing it comes with fittings. More than you will need. Make the lines your self. I just did my whole truck with this stuff. It works great and it's no problem double flaring it.
https://www.summitracing.com/parts/s...EaAuD2EALw_wcB
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-20-2020, 02:57 PM   #8
HO455
Post Whore
HO455's Avatar
Just for clarification you are talking about the hose from the axle to the frame crossmember not the hard lines on the axle?
RIP Bob Parks.
Old 02-20-2020, 08:48 PM   #9
CJ2A
CJ2A's Avatar
Yes, the rubber hose from the brake hard line at the rear of the frame to the rear end.
I seem to find the correct one and then it is only 18" long (same as stock). I should have something longer because of the 4" lift and the current tension on the old rubber line. When I would find a longer line with the correct configurations the vehicle description would say TJ/YJ/CJ. With those jeeps being listed as correct for the rear rubber hose I was worried about the threads being correct for an older Chevy Pick Up.
Thanks for the leads everyone.
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
Old 02-21-2020, 01:44 AM   #10
HO455
Post Whore
HO455's Avatar
I have always found that going to NAPA worked well for trying to come up with brake hose modifications. My other suggestion would be to do a search of the 4x4 section for a longer hose post. I'm positive you're not the first one doing this.
RIP Bob Parks.
Old 02-21-2020, 06:10 AM   #11
Andy4639
Old member
Andy4639's Avatar
Here is who I used for my 71 C 10. They will make you any size any length you need.
https://www.ebay.com/itm/33068258265...:MEWAX:IT#shId
