02-21-2020, 12:07 AM | #1 |
Swapping from 327 to 454
I have spent all of my time on this forum in the Heavy section. I have a C50 Heavy Hauler but got no replies in that forum. It came with a 327 that it still has and runs actually pretty strong but uses a gallon of oil per mile without smoking.
I was advised to go 454 rather than building a 383 stoker because I'd get more torque for my money. The reason for going 383 was that I assume I wouldn't need to change anything, it'd drop right in; but the torque of a 454 did sound nice. Does anyone know if swapping a BBC into a C50 is any different than a c10/20? What needs to be overcome to do this swap? Is it particularly invasive and expensive? Any advice would be appreciated. Thanks y'all. |
02-21-2020, 12:14 AM | #2 |
The Older Generation
Re: Swapping from 327 to 454
See if there is anything in this thread that will help. http://67-72chevytrucks.com/vboard/s...d.php?t=800919 LockDoc
02-21-2020, 12:55 AM | #3 |
That thread alone is very helpful, thank you very much! Quite frankly I think I might be reconsidering a 383 versus remounting the trans crossmember and shortening the driveshaft...
02-21-2020, 09:01 AM | #4 |
If I was starting from scratch like you and had no BB parts, I would also go 383. And if you had a little more $ to throw at it, maybe even a 415 or 434. SO much easier to use all the parts you have and not have to get more.
383 an excellent bang for the buck. While I have a bunch of big blocks, am planning a 383 build for my Jimmy for all of those reasons.
02-21-2020, 10:37 AM | #5 |
A moment of Devil's Advocate: all the parts for the BBC should be easy to find as so many of those trucks came with 427s.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
02-21-2020, 10:51 AM | #6 |
Not that I am even a heavy truck novice or even close...basic things to vet out by just upping from 327 to 383 would be...
Radiator cooling capacity - Often times a bigger engine means bigger radiator. Larger exhaust/intake manifolds may be needed with more flow potential. Maybe even a larger carb. I'm not sure how far you plan to go...I guess you are trying to figure that out, so I am just throwing in my 2 cents. I can certainly understand the urge to go BB, but that definitely changes the budget. I wonder if the front suspension would need heavier springs if you went BB???
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
02-21-2020, 12:58 PM | #7 |
4BT with an allison....just throwing it out there
02-21-2020, 01:12 PM | #8 | |
'67 c10 cst farm truck |
02-21-2020, 01:19 PM | #9 | |
https://67-72chevytrucks.com/vboard/...play.php?f=239
02-22-2020, 12:09 AM | #10 | ||
Exhaust would be completely replaced. Most of it is original and atrocious. Carb now is a 2bbl....I don't even think there's such thing as a 2bbl intake that was ever prodiced for BBC.....were there? LOL @ front suspension. Man this truck has 7,000 lbs. springs for the front end, I think we're good. Easy Easy there. I haven't even got an engine yet. Thank you all for the posts, I hope you don't take me too seriously. I really want this swap, but I also don't know a lot about swaps, soooo.... |
02-22-2020, 12:37 AM | #11 |
Your truck ...but in a big husky fellow like that I'd find a Cummins Powered parts truck and swap it out.
