02-21-2020, 12:51 PM | #1 |
Ididit column
I got the Ididit column from Speedway, Ididit 1120320010 Tilt Wheel Steering Column, 32 Inch, Plain
Universal Fit, Tilt Column Type, Floor Shifter Location, Dash Key Location, 32" Overall Length I plan to use the ignition switch in the dash, so no switch on the column. The issue is there is also no NSS on the column either. Does anyone know how to add a NSS into this set up? I know there must be a way, but I've spent 3 hours trying to figure it out and really could use some help. Thanks, Robert
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
