Old 02-21-2020, 04:25 PM   #1
Awann99
Brake lines conversion tips
I’m working on a friends 1965 gmc. He still has the single master cylinder but it needs to be replaced along with his brake lines. I told him it would be best to swap to a dual master cylinder, disc brakes and stainless steal lines for safety if he plans to daily drive it. He doesn’t want the disc brake swap at the moment due to money but he does want a dual master cylinder. I checked brothers and inline tube and they do not carry dual master cylinder lines unless you are converting to disc brakes. The engine is in the truck so bending a custom line would be a pain. Would it be better to use 67-70 drum brake lines because the frames are the same? Or use the disc brake conversion lines with drum brake hoses. Thanks.
Awann99 is offline   Reply With Quote
