02-21-2020, 06:43 PM | #1 |
Need some steering wheel help please
Trying to get the Blazer useable. It has a crappy Grant steering wheel and the horn does not work. Messing around I can get the horn to beep (sounds sick) with a jumper. I believe the turn signal cancelling cam might be messed up so I ordered one of those. I want to put a later model Chevy steering wheel on for now like the one below. This is on a tilt column if that matters.
And there is this diagram from grant. It shows a spacer/sleeve is this supposed to be there? I don't have one? Are there any other part that I should need other than the wire that plugs into the cam?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
02-21-2020, 10:29 PM | #2 | |
Re: Need some steering wheel help please
The wheel will fit fine on the tilt. Below are pictures of the leather covered version of the same wheel in my truck and 4 that show how I modified the horn contact to a horn wire. Ignore the condition of the column in the last picture. It's a spare I used several years ago just to show the installation in an old post. |
02-21-2020, 10:54 PM | #3 |
There's usually a spring under the cancel cam, but it may work without it.
Nice job on the spring to wire contact.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-21-2020, 11:05 PM | #4 |
02-21-2020, 11:29 PM | #5 |
There is no spring under my cam. I had to push it down to get the horn to sound with a jumper. Horn sounded weak. Need to get all the parts, buy a wheel (want leather) and get all that installed then see if it the horn, relay, or grounds that is causing the weak sound?
I believe there is a light under the lens. Going to see if I can get that working?
02-21-2020, 11:59 PM | #6 | |
Yes, there should be a light under the shift indicator lens. If you are lucky it'll have a metal cap and green plastic filter over the top of the bulb (see picture). I believe the bulb is a 1445. |
