Old 02-23-2020, 06:12 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
New enigne with electronic throttle in a classic. How??
So I may be getting a motor from an '05 Silverado, 5.3, but it has an electronic throttle. Is there a kit that let's me put a cable TB on the engine? Thanks.
desert-rat is offline   Reply With Quote
Old 02-23-2020, 06:41 PM   #2
Thealien
Thealien's Avatar
Re: New enigne with electronic throttle in a classic. How??
Why would you want to do that? Electronic works just fine and you can have cruise control easily with DBW. Just mount the pedal that comes with the engine and the TAC module. Many have had to cut the pedal off the electronic pedal assembly and weld or bolt the factory pedal at the height and position you want. That way the gas pedal matches the brake.
Old 02-23-2020, 10:55 PM   #3
desert-rat
Now that's a reply I can live with. Thanks. This will work.
Old 02-23-2020, 11:36 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New enigne with electronic throttle in a classic. How??
If you go to the LS swap area you will find all the answer's you have.
The 6.0 I have with 4L80E over drive is cable driven. Cruise control and all. Drive by wire is nothing to do but I like the feel of the cable myself. Either one is fine though.
Check the link and do some reading.
http://67-72chevytrucks.com/vboard/f...prune=-1&f=206
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-24-2020, 08:08 AM   #5
I think you have to hook the wire to the gas pedal
Old 02-24-2020, 03:51 PM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
What alien said will work...I've used both dbc and dbw...I was wanting to swap my dbw to cable, but when I talked to psi they said I'd have to get a red/blue ecm to do that...and find a cable throttle, so I stuck with the dbw setup...a few mods to the mount and it works fine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-24-2020, 07:02 PM   #7
bigmoe
bigmoe's Avatar
I went dbw on my swap (gen IV 5.3, 4l60e). I got the truck pedal but it didn’t fit and I was unable to modify the weirdly shaped plastic pedal. There are a few car pedals that other swappers find easier to modify. It’s nice to mount it and plug it in and not worry about a cable conversion.
bigmoe is offline   Reply With Quote
