Old member
This is just for discussion on a 71 C 10 tilt wheel steering column.
I have been looking at my manual's the past few days and ran across this in my 71 Manual. This is a blow up of the parts list of a tilt column out of the manual. There is no mention of the spring are the turn signal canceling cam in this parts list that I can see. Am I missing something? Per these 2 topic's there should be both. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=544819 http://67-72chevytrucks.com/vboard/s...d.php?t=515103
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Tilt Steering ??????
My guess would be it is just part of a different sub-assembly in the book. Mine is out in the shop or I would thumb through it.
#3 | |
Old member
![]() Quote:
The Older Generation
I don't have my manual in the house either. Could the cancel cam be a part of the steering wheel group? EDIT: This is from the Assembly Manual. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-23-2020 at 10:15 PM. |
#5 | |
Old member
It's definitely there in that picture Doc! I just wonder why it's not in the manual since all the other major parts are. I just bought the Chevy/GMC assembly manual. ![]()
The springs on the TS switch? Available aftermarket but I don't think GM ever serviced them separately.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
