02-23-2020, 08:25 PM | #1 |
Junior Member
kick panel vent gasket
Looking for recommendation of material to use for kick panel vent. I bought a gasket set through a vendor but the material doesn't seem right. Any recommendations?
02-23-2020, 08:31 PM | #2 |
Re: kick panel vent gasket
you can but them from classic parts of america web site they are $3.99 a pair https://www.classicparts.com/
02-23-2020, 09:17 PM | #3 |
Junior Member
anew4961 have you used them? The ones I have bought don't seem to be comparable to the factory material.
02-23-2020, 09:34 PM | #4 |
Old member
I bought the whole vent flapper for the 68. I have also cut inner tubes up to use as the gasket and they seal better than the new ones do and they will not hang up.
02-23-2020, 10:54 PM | #5 |
I just bought some rubber sheet , This ebay seller has it cheap with free shipping and different thicknesses to suit your project , I used it for the flapper vents and as a vibration layer between my rear mounted fuel tank and the frame .
https://www.ebay.com/itm/Neoprene-Ru...YAAOSwlgdaf89j
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
