Old 02-23-2020, 11:39 PM   #1
Jcfcamaro
Jcfcamaro's Avatar
1972 side moldings
Has anyone drilled extra holes like the earlier trucks to hold the side trim on better instead of using the 3m adhesive tabs the 71 and 72 went with. Just seems like it would work better.
Jcfcamaro is offline   Reply With Quote
Old 02-24-2020, 12:56 AM   #2
allchevy58
allchevy58's Avatar
Re: 1972 side moldings
I'm in the process of doing that. Bought all the clips and going to drill the holes.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 02-24-2020, 02:25 AM   #3
Jcfcamaro
Jcfcamaro's Avatar
I'm planning on it also. Just wanting to see what everyone else thought about it. The 3M tape doesn't last forever.
Old 02-24-2020, 05:25 AM   #4
72supr
I did.Like you just thought it would be a lot better than the tape.
72supr is offline   Reply With Quote
Old 02-24-2020, 07:51 AM   #5
That's how I've always done it. Never been a big fan of stickum on vehicles
Old 02-24-2020, 11:05 AM   #6
Jcfcamaro
Jcfcamaro's Avatar
Did you guys use the ones that push in or the ones that have the threaded stud with the nut ?
Old 02-24-2020, 02:16 PM   #7
72supr
I put the new lower trim on mine and just used some of the old clips along with some new ones. Funny looking little gizmo with a wire spring that glued on to the moulding.Do not know what kind of caulk was used originally but I remember I had quite the time getting the clips off the old trim.Maybe your talking about the upper molding which might be glued on I’m not certain about that.
